Old 09-25-2004, 01:53 AM
Maximum Race Engines Maximum Race Engines is offline
As of October 1st, all new IA2 engine blocks will feature the main caps registered in the pan rails. They will no longer incorporate dowel pins. The pan rails have been raised .125" in order to register the main caps, which will be a better, stronger way to help minimize any main cap movement as much as possible, especially with high rpm/ high horsepower combinations. By doing this, the blocks will now need a longer oil pump drive, which will be included in the block hardware kit that is being sold by ALLPONTIAC, Spotts Performance, Maximum Race Engines, and anyone else that will be selling the block.
To those that do not know by now, each block now incorporates screw in style freeze plugs. These screw in type plugs will also be included in the same hardware kit. The block hardware kit will include everything needed to prep the IA2 block.
Joe Pontiac
www.maximumraceengines.com
[email protected]
Joe Pontiac
[email protected]
Old 09-25-2004, 07:44 AM
PONTIAC DUDE's Avatar
And also Ken's Speed & Machine Shop.
Your AllPontiac.com block distributor.
Old 09-25-2004, 08:15 AM
I can see the benefits of the outer edge of cap register for locating the cap. Several different production blocks have come that way. My concern would be the cap wanting to pull inward under high leads like a rod cap does. Maybe this is not an issue as the main caps are so much larger (stronger), made from
better steel, and the crank wanting to "orbit" around the whole
main cap under high rpm conditions vs the rod cap seeing high inertial (tension) loads at the same rpm.
On the race blocks Jimmy Keen ran (Production Race blocks from Ford) we machined registers in the block webbing for each main and had custom caps made with "tangs" vs dowel pins/ outside
registry like is being reported. NO fretting, no block issues after that on the Keen stuff.
Hope it works well. Some one is thinking.
Old 09-25-2004, 08:20 AM
Ray Cox's Avatar
Ray Cox Ray Cox is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by PONTIAC DUDE:
Your AllPontiac.com block distributor. <HR></BLOCKQUOTE>
Dude the info about the registering has been out for weeks how come your always following? gotta start leading both with the post and ETs this coulda been your post weeks ago
8.30 @ 165 mph 3,380 LBS
Old 09-25-2004, 09:17 AM
Ken-
Didn't forget about you . Just wasn't sure, and it is not my place to mention you without knowing your involvement. Besides, I figured you would jump in and make it known anyway..Just letting you get some air time.
By the way, shouldn't your phrase say...
"One of your ALLPONTIAC.com block distributors..." lol
Joe Pontiac
[email protected]
Old 09-25-2004, 09:19 AM
Ray Cox's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Maximum Race Engines:
Ken-
Joe Pontiac
http://www.maximumraceengines.com
[email protected] <HR></BLOCKQUOTE> ya gotta love it
Old 09-25-2004, 01:38 PM
Ken be modest? Ha! Ha! Ha! Ha!
Ken believes the world revolves around him, didn't
you figure that one out?
Old 09-25-2004, 03:01 PM
10second70GP's Avatar
10second70GP 10second70GP is offline
hey can i emailed you about doing a IA2 SHORTBLOCK BUT YOU HAVEN'T REPLIED TO MY EMAIL ?
Old 09-25-2004, 03:02 PM
DAMNIT I MEAN KEN
Old 09-25-2004, 08:09 PM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
Can someone post pics of the new caps. I don't know what you mean by <BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> all new IA2 engine blocks will feature the main caps registered in the pan rails. <HR></BLOCKQUOTE>Thank you
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 09-25-2004, 08:24 PM
crossbreed455's Avatar
crossbreed455 crossbreed455 is offline
they are like a bbc caps. the pan rail is .125 lower if block is upright.
mike m.
Old 09-25-2004, 08:28 PM
Robert C.'s Avatar
Robert C. Robert C. is offline
Allpontiac.com looked at the other brands of motors out there that have caps registered in the block. This was done because dowel pins are old technology. High speed film as shown caps can dance around in a block. You can even break a dowel in a cap and not know it until it is too late. We have added this at no extra charge to the block price. Up grading our product is an on going process. We plan to pour alum. blocks in the fall if there is a demand. We need to have 15 deposits to make it worth our time to do this. We have a list of people that we will start to call on soon that want an aluminum product. You can trust that we will put the same quality in that product as we are doing in the IA II block. We hope to have one soon.
Also, we added threaded freeze plug holes in the IA II at no additional cost. This is a way to bring the outer walls of the block more strength by pushing 360 degrees around each hole. This pressure will add strength to the outer wall. It was not to have a screw in plug to look cool. We copied a Ferd design. I wonder were we got that idea.
Bob C.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads
Boss Bird Funny Car
Best pass to date 08/06/2016 [email protected]
Allpontiac Big Chief Aluminum Engine Block
http://www.AllPontiac.com
Old 09-25-2004, 09:54 PM
Mo's Avatar
Mo Mo is offline
Bob, awesome job on those blocks, a real work of art. Now that we have all these great blocks and heads is there any chance of an AllPontiac.com forged crank? We really need on to fill the gap between cast and billet. Thanks
Systems under stress fail catastrophically
Old 09-26-2004, 09:46 AM
I suspect with your new machining company you will be using that Ferd knowledge a lot. Not
only do they have their experience but they have access to other Ferd people who can provide
advice from modeling simulations.
Glad you guys are doing your best on this.
Old 09-26-2004, 11:32 AM
Robert C.'s Avatar
Mo, Thanks.
QuoteNow that we have all these great blocks and heads is there any chance of an AllPontiac.com forged crank? We really need on to fill the gap between cast and billet.)
Heads? What head is a great head? I know of no head out there for a Pontiac that is a great head. YET We are looking at cranks and heads too. We will make sure that we follow thru and will not lead people on as to how good they are or we will have them next week like others have done.
Bob C.
Boss Bird Funny Car
Old 09-26-2004, 12:35 PM
Mo's Avatar
Mo Mo is offline
Bob, I think if your into N/A motors then yes you could use a better head. However, the trend appears to be power adders. As a person in the process of building a turbocharged motor my concern is not head flow but rather keeping the bottom end together. I would buy an Allpontiac.com block in a heartbeat, its a no brainer, however the thought of my $400 cast crank taking out my $2995 block when I'm making 1200HP at a significant RPM is enough to keep anyone awake at night. I think more guys would spend the extra money on your block if they new a good crank was available other than a billet. JMHO
Old 09-26-2004, 02:12 PM
"Heads? What head is a great head? I know of no head out there for a Pontiac that is a great head. YET"
What would you call a great head? 375 cfm at 28"?
425 cfm at 28"? A 500 cfm head?
A buddy of mine created a 450 cfm pontiac head about
10 years ago from a billet. It had a SB-2 style port
spacing configuration but used a very good (at the time) BB Chebby Dart port with a 2.19 intake valve.
Two issues with the head were, at that time, the lack of an intake manifold (custom built reqd) and the shaft
valvetrain set-up.
Today a shaft set-up could be created to work with the
Intake/Exhaust pattern and the IA-2 block would be able
to handle the required bore size increase.
It would probably be an alcohol head though due to being a billet.
Let me know if you need more info when you want to build a BIG head.
Old 09-26-2004, 06:22 PM
"What would you call a great head? 375 cfm at 28"?
425 cfm at 28"? A 500 cfm head?"
Nope. None of that matters.What good are those numbers if the port is too small? A great head would be one with enough VOLUME to feed the bigger inch engines. Forget the number on paper, aim for a head that has enough volume to feed the combination. That is what Bob means. There are none out there, yet.What is availabe is borderline for 512 inches, let alone bigger. A head that offers enough volume for the big inch engines, not just a small block chevrolet port size on big inch engines with big flow numbers on paper. The question is not what needs to be done to make a big head. I have discussed for months with Bob and Frank what needs to be done just like I did with the block before it was made, but they need to figure out how first, and if it will be good to do financially. They have the resources, and they are very intelligent business men. They are just not rushing into it.
Joe Pontiac
[email protected]
Old 09-26-2004, 06:59 PM
I would say this block is probably as good as it could get right now.Are the roller cam bearings ready to install a option currently?I would bet once Bob and Frank are content with the blocks and some of the investment comes back,the next project will be done the same way Correctly!!Bob told me a while back he would do it right or not at all.Thanks for your efforts and save one for me when the house is done.Brian
