Old 08-19-2003, 07:33 PM
schlitzman's Avatar
schlitzman schlitzman is offline
What plug gap can/should I use with electronic ignition? I have a '66 389 w/4 BBL, Mallory Unilite ignition, 44s plugs and 11:1 CR. Thanks for help.
schlitzman's Avatar
Old 08-19-2003, 08:11 PM
Blackfoot Blackfoot is offline
1970 400/6X heads/MSD hei distributor and a 6AL box/AC Delco 45ts plugs set @ .45. I've tried them at .50 and I personally think mine work better at .45. I tried Autolites and went back to AC's.
I've got a babys brain and an old mans heart,..............
Old 08-20-2003, 03:01 PM
Kenth's Avatar
Kenth Kenth is offline
Mallory Unilite is not a high energy ignition system.Use the factory settings,.035".
Can“t imagine what kind of system that would ignite a .45" gap :-)
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 08-20-2003, 04:04 PM
SupergasDil's Avatar
I had my plugs gapped at .050 with the Blaster II and MSD6AL. Talk about a flame thrower. It was like snappy lightning.
Old 08-20-2003, 05:15 PM
Hey Super, I'm running the same setup but seems to run run better for me at .45. Your probably running a bigger cam.
Old 08-20-2003, 05:29 PM
Never Enough Power Never Enough Power is offline
Motor seems to like .045 with MSD unit and AC plugs. You can try a couple of different ranges till your plugs fire the way you want them to. Watch the color of the plug as you change the gap to see which one burns the best.
