Old 10-09-2004, 08:49 AM
FantomPoncho's Avatar
FantomPoncho FantomPoncho is offline
I was out changing the oil and filter on my '66 Lemans and cursed the whole time trying for the umpteenth time to get the filter off without dousing the headers with oil. I figured there's a lot of you guys with the same problem. What kind of things do you do to avoid the oil mess?
One thing I tried was to wrap the filter in a plastic shopping bag, then remove the filter. Let all the oil drip into the bag, wrap up the filter then wrangle the filter out. So far it seems to work ok, not perfect, but ok.
Any other ideas?
Any other ideas?
Old 10-09-2004, 09:54 AM
shaker455's Avatar
I've never changed the filter without wiping off the mess after...
Old 10-09-2004, 10:09 AM
Ryche400's Avatar
Ryche400 Ryche400 is offline
Same here. What I really hate is the smoke coming from the header as your driving away. Sometimes it seems like forever before it stops smoking....
Old 10-09-2004, 11:03 AM
Young One79TA Young One79TA is offline
Yea. I just wipe it clean and let it idle in the driveway to burn the rest off.
Old 10-09-2004, 11:47 AM
BN's Avatar
BN BN is offline
I've heard of drilling a hole in the filter to drain it before loosening. Sounds like a lot of work though. I use a large ziplok bag and twist it off with that letting the filter and oil fall into bag, not perfect though.
Old 10-09-2004, 02:45 PM
burch burch is offline
I just drape a large plastic bag over the headers before unscrewing the filter. Still makes a mess but it keeps the oil off the headers.
Old 10-09-2004, 03:11 PM
BN,
I like the idea of drilling a hole in the filter. Takes a couple a seconds to drill, drain the oil and remove the filter. Good idea!
Old 10-09-2004, 03:12 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Bn, The bag is a GREAT idea. So simple,now why didn't I think of that before my last oil shower! -LOL. -Jim
Old 10-09-2004, 03:13 PM
Jeff R's Avatar
Jeff R Jeff R is offline
I agree with several here, plastic bag. I use a kitchen-sized, plastic garbage bag pulled up behind the filter, draped over the headers and down into the drain pan.
Old 10-09-2004, 03:50 PM
DiamondJim's Avatar
I'm thinking, break the filter loose and then slip on a gallon size zip-lock bag that has the zipper handle...-Jim
Old 10-09-2004, 04:48 PM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
at least you can get your oil filter out.
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 10-09-2004, 05:51 PM
BN's Avatar
BN BN is offline
Hey guys I forgot to list the most important item, latex gloves. Keeps the hands clean.
Old 10-09-2004, 06:08 PM
wheelspin's Avatar
Even using the above methods, I found myself waiting for everything to cool off as the oil thickened . I installed a remote oil filter setup, which is the best technique for taking the hassle out of this task .
Les
Les Iden
Old 10-09-2004, 06:13 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Just bend an old license plate to hang over your headers....works great!
I use that method at work on some poorly designed/located filters.
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 10-09-2004, 06:32 PM
DiamondJim's Avatar
6D6, I have a 66 also with Hooker SC's. I have to use a skinny filter and even then it is a tight squeeze. I use the NAPA 1045 Gold, made by Wix. Before I foung the 1045 I had to unbolt the 3 housing bolts. -JimT
Old 10-09-2004, 08:56 PM
Murf Murf is offline
I wrap "tin foil" around the headers before I change the filter. It works pretty well for me.
Later, Murf
Old 10-09-2004, 09:45 PM
mikeb mikeb is offline
I use a large chunk of cardboard from an old box to redirect the oil flow away from the headers, and toss it in the trash afterwards.
Old 10-09-2004, 10:02 PM
Jack Blum's Avatar
Jack Blum Jack Blum is offline
I use the plastic bag the store give to carry the filter and oil home in. Just wrap it around the filter (after loosining it), the oil and the filter drop right into the bag. No mess at all. But I do have to put a couple of rag for the drips from the adapter.
TigerEFI.com (Classic Pontiac Fuel Injection)
2004 GTO Company car, 1994 TA 25th Anv, 1971 Grand Safari Wagon, 1968 GTO EFI, 1968 GTO Stock, 1968 GTO Convertible in desperate need of restoration.
Old 10-09-2004, 10:10 PM
6D6GOAT's Avatar
thanks jim, yea i've heard of people using the thinner one. i bought an oil filter relocation kit..im still sitting on the fence with keeping the headers or throwing the stock logs back on.
My T56 Install
My Turbo Build
Misc Build Pics
