Old 03-03-2000, 08:50 PM
PROBRD PROBRD is offline
Does anyone else have a problem with windage trays cracking? Just about everytime I pull the oilpan off it has a few places where it has cracks. I replace it with another one and the next time it is cracked again. What causes this? How do you keep it from happening? Are there any advantages or diadvantages of not running one? I've heard of people running without one. They run a deep pan and run a quart low on oil. Anyone tried this?
PROBRD
([email protected])
1/8th mile 6.52 @ 104
1/4 mile 10.43 @ 128
PROBRD
([email protected])
Old 03-03-2000, 10:34 PM
Old Man Taylor's Avatar
I have seen this a couple of times. A friend of mine lost a piston and a set of bearings this way. The tray came apart and pieces went everywhere. This was a full windage tray. I now weld straps to each of the stress points, and I weld bars under the attaching bolts. I am more comfortable with the tray than without it. Why does it do this? I am not sure. It might be the engine harmonics, or it could be forces from the oil whipping around. I really don’t know, but the cracking is not that rare.
Jim
Old 03-04-2000, 01:33 AM
Tom McQueen Tom McQueen is offline
Mine have cracked as well. Welding and bracing are the only solution. Sorta suggests we could use a good aftermarket windage tray, huh. One that works with the 400, 428 and 455. One that accepts a dipstick. Teflon coated maybe, with lots of drain holes. Must be a dozen available for that corporate motor.
Check out my 70 GTO build;
http://www.yellowbullet.com/forum/sh....php?t=1148602
Old 03-04-2000, 03:54 PM
Tom Wihite at one of the Pontiac Southern Natls mentioned he saw it more with his launching on the rev limiter and maybe the stutter and harmonics from it. I've heard more about the full length ones doing this than the 3/4 tray also.
Bought a Moroso when they first came out, only fits 2 bolt mains unless notched and no dipstick tube provision. (need to trial fit my "fix" two holes where the standard non tray tube bolts to main cap to access bolts and a slot to slide that part of the tube through the tray.
Old 03-04-2000, 05:18 PM
I believe the shorter tray is actually a little bit thicker. The cracks in the ones I am aware of were in stick shift cars, no trans brake.
Jim
Old 03-05-2000, 11:16 PM
roger van doren roger van doren is offline
Does anyone think powder coating the windage tray may help stregthin it?
roger
Old 03-06-2000, 01:17 AM
Todd Todd is offline
[This message has been edited by Todd (edited 07-18-2000).]
Old 03-06-2000, 05:25 PM
Big Injun's Avatar
Big Injun Big Injun is offline
Ken Brewer at Pacific Performance has worked with Milodon to develop an aftermarket tray. I have seen it and it is of a heavier gage that will not crack.
However, it does not have a provision for a dip stick tube. It can be modified to use one.
Ken has them in stock at 310-832-4596
www.PontiacDragDays.com
Dave "Big Injun" Anderson
[email protected]
www.4mypontiac.com
For GTO Celebration items click the tile coaster.
Old 03-06-2000, 06:15 PM
PONTIAC DUDE's Avatar
The Milidon pan is not made to bolt to the main caps like the factory unit. It bolts like the aftermarket chevy types, off the mains studs with threaded top section and nuts top & bottom of the tray. They use the Cheby main stud kit. Nice looking pan but requires work & money. Later.
Old 03-06-2000, 06:57 PM
Triggerman Triggerman is offline
Just my opinion, but I feel windage tray cracking must be related to vibrational effects in the bottom end. Cracking in a thin member of this nature is a result of metal fatigue and the metal of a windage tray has no forces exterted on it (to fatigue it) except thru harmonics and vibration. A full length tray has more material to form a lever arm to work against the stress points with, which might explain why they are more likely to have cracking. I suspect any bottom end which is completely balanced will have less of a problem than stock assemblies. I've never cracked one, but I've ran an aftermarket assembly for the last 8 years which is attached into the pan and not to the bottom of the caps (it's also thicker than a stock unit). Precision balancing, thickening the stress points and/or possible heavier aftermarket units is the answer here. Not an item you want to come apart and mingle with the rods at any rpm. Any other thoughts on this? TM
Old 03-06-2000, 11:11 PM
Paul Spotts's Avatar
Paul Spotts Paul Spotts is offline
I had a tray come apart in my old motor
(I hate using the past tense term). I have a factory tray(long)mounted on studs with rubber washers allowing the tray to "give" a little. It never cracked. Many larger race engine friends of mine just do not use the tray. I have heard the trays cracking mostly with higher lift roller cam engines. I have to agree with TM - yet the oil pounding therory may play into the effect. High speed oil pounding the tray could cause vibration or a rocking effect. The factory designed these trays for max RPM's around 5800 - my engine has seen 7000 many times. If I'm not mistaken - the long trays were only on the 400's and the shorter trays on the 428 and 455's. I think the short trays are thicker as well. I sell a lower dip stick tube that has a bracket welded to it for cars not using a windage tray. It mounts to the main cap - not sure if the Milodon pan will allow this to be used. I applaud Milodon and Ken as well for the continuing parts being introduced.
[This message has been edited by Paul Spotts (edited 03-06-2000).]
www.spottsperformance.com
East Coast Pontiac engine builder - still going strong
4 month waiting list
email [email protected]
1981 Trans Am 455 w/6X heads 4 speed 4 wheel disc (for sale)
1969 Trans Am clone 9.79 at 139 so far
1964 Banshee clone project - Opel GT platform
Old 03-06-2000, 11:23 PM
WARPed's Avatar
WARPed WARPed is offline
Matt, were did you get your pan rail mount windage tray? Is this your own concoction, a one-off of a cheby design, or does/did someone offer this?
[email protected]
[email protected]
[email protected]
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 03-07-2000, 01:45 AM
If I remember right Warrior racing had one called a Ray Tray. I'm not positive because I can't find my old catalogue. Has anyone used one of these? I may give them a call to see what they have. Paul, do you run with or without one?
Thanks for all of the input guys!
PROBRD
([email protected])
Old 03-07-2000, 06:36 PM
Old 03-07-2000, 10:37 PM
on stockers, were exactly have you guy's ( old man and tom)added peices of metal for stregth? i am using the stock one on a 400
roger
Old 03-08-2000, 12:25 AM
Warped, it is the Canton pan in Warriors catalog that has the full side kickout. I've been pretty pleased with it's oil management capabilities, I just wish it fit when they sent it to me. Then I really wish it fit when they sent it back to me the second time. At that point I took a torch and modified it to fit. Then it fit! Come by and I will show it to you, I'm getting ready to dis-assemble. TM
Old 03-08-2000, 12:33 AM
As an addendum to this line of thinking. There are a few aftermarket manufacturers that you can just purchase a generic tray from. You can then weld tabs into your oil pan for it to mount to and avoid having it connected to the bottom of the caps at all. In the interest of fair reporting Jim H. pitched his view to me of the oil pressure coming off the crank as a possible factor in the cracking. If this does have some effect it would have to be (IMHO) because the fluid is causing the thin material of the tray to "flutter" and fatiguing the metal....at some point resulting in cracks. Thicker material at the mounting points would combat this.
Old 03-08-2000, 12:01 PM
Ken -Ace- Brewer's Avatar
Ken -Ace- Brewer Ken -Ace- Brewer is offline
Send a message via Yahoo to Ken -Ace- Brewer
Guys,
I am sorry about the new windage trays not fitting 455's. And the dipstick hole? We just use a inner dipstick tube from a normal windage tray motors. And tack it to the block after the tray has been installed.
We are in the process of building a KILLER oil pan for our pontiacs! It will have a windage tray AND a crankscraper AND trap doors! Just for drag racing!! These pans are being CUSTOM made to my specs! Any suggestions?
Be Cool,
ACE-P.P.R.
Am I glad I got out of the business I was in? HELL YEAH!!!
Old 03-08-2000, 02:47 PM
Ace,
Only suggestion I might have is to have a version of this pan that will work with the new belt drive from BOP. Looking forward to seeing these new pieces. What pan capacity are you considering?
