Old 03-17-2003, 11:45 PM
Got the entire engine all buttoned up, the Canton tray, Spott's scraper, Milodon pan, Milodon pick up, Dynagear pump, dipstick tube(s), & all seals blueprinted and JAM UP! Looking real good w/ required tolerances.
But guess what I find that I forgot???
My damn oil pump drive!!!
Whaddaidiot!
So now rather than dissassembling the pan assy. I'm thinking about removing the two swaged protrusions on the upper shaft & installing it from above. Anyone think this will present a problem in operation? Obviously we ain't purposely running it upside-down.
Whaacuthink?
SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY.
I Misus Rash'!
Whaddaidiot!
Whaacuthink?
I Misus Rash'!
Old 03-17-2003, 11:59 PM
No it will work fine from what i have been told.
Althoe i figure they put those bumps on the shaft for a reason...Maby its just in case you flip it upside down so the shaft wont fall out. But i dont see it presenting a problem since the pump is bolted in and the Dist will be bolted in dont seem like there is any way for it to come out.
Mike
Old 03-18-2003, 12:11 AM
That's what I was thinking. But gotta run it up the flag pole, just to see who salutes.
Any other opinions? Not about me being an dumbass, we've already established that.
I Misus Rash'!
Old 03-18-2003, 12:26 AM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
Larry, I read somewhere, but I can't remember where (CRS) to grind off the tangs, drop it in and don't worry about it.
(CRS) = Can't remember ****!
My Rig's a little old, but that don't mean she's slow.
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 03-18-2003, 12:32 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Larry, I'd bet there are more than a few who have frgotten the oil pump shaft at least once, but won't admit it. Some 25+ years ago I was helping my best friend assemble his '67 GTO engine and we forgot the shaft. He ground off the two tangs and dropped it in. Ran for many years and miles like that!
Lloyd
'72 Formula 400 - soon to be a 455HO, TH400, A/C, etc.; Lucerne Blue with Medium Blue Interior
Restoring a '72 GTO 455HO, TH400, A/C, etc.; Sundance Orange with Parchment buckets
Regards,
"455HO" Lloyd
Old 03-18-2003, 06:29 AM
Bill Meyer's Avatar
Bill Meyer Bill Meyer is offline
Location: West St Paul MN/Mesa,AZ- depending on weather
O.K. - I'll admit to doing the same thing! Ground them little sucka's off ,stuck it in and no problems. Bill--
GT37 3600lbs...as featured on the cover of Pontiac Enthusiast Jan/Feb 2002 DOT/mufflers-all motor
6.49 @ 108
10.14 @ 133
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
Old 03-18-2003, 06:58 AM
sleepy's Avatar
sleepy sleepy is offline
Those tags are to lock the shaft in place so it doesn't come out with the distributor. You don't need them. Just make sure the shaft is in place when you put the distributor back in.
Why is he not suspended?
Old 03-18-2003, 07:06 AM
J.C.you's Avatar
J.C.you J.C.you is offline
I've done this for years thru many engines with no bad results. Get u a good extended type magnet that will hold the rod by itself, take a lite and note the position of the oil pump drive. Ease the rod in the hole with the magnet and use a long flat head screwdriver to adjust the rod a little to get the rod to drop on the drive. When it drops in the slot hold the rod with ur screwdriver and take the magnet off. Use ur screwdriver to turn the rod and make sure it is in the rite position. U can get the rod off to one side, but iv'e never got one stuck or dropped one into the pan.
wanna race? gimmie the move--
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 03-18-2003, 07:20 AM
Lemans1 Lemans1 is offline
I have dropped one into the pan doing that once...that is one thing I will NEVER forget!
The engine was already in the car and hooked up, it was one of my first rebuilds. Went to put the distributor, and no shaft...talk about pissed. But when I dropped it in the pan... Determined no to pull the engine, it took me about 3 hours to get it out...jacked the engine up, dropped the pan...etc, etc... Good luck and be careful not to drop it!
"Artificial intelligence is no match for natural stupidity."
Old 03-18-2003, 08:12 AM
all_ryze all_ryze is offline
I belong to that club too!
No problems yet, distibutor pulled plenty of times.
MOTOR CITIES FINEST
PHS Documented "REAL JUDGE"
12.53 @ 110.68 on street tires, through the mufflers and a 4 speed!!
Worlds Fastest Documented GTO JUDGE!
Old 03-18-2003, 09:42 AM
Glad I'm not the only one.
I Misus Rash'!
Old 03-18-2003, 10:03 AM
ventura7211's Avatar
ventura7211 ventura7211 is offline
I'm pretty sure the trick to install the shaft comes from pete mccarthy's book.I forgot the shaft too once.
Old 03-18-2003, 04:09 PM
Gooatee's Avatar
Gooatee Gooatee is offline
See, some of us are not too cool to admit we make mistakes! I too have to admit I have done it and survived!
Old 03-18-2003, 04:16 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
I have a oil pump driveshaft in my GTO from HO Racing. It doesnt have any tabs at all. I tried to make it fall in the pan while the engine was still on the stand but it wouldnt. Different diameter maybe? You out there Ken?
Old 03-18-2003, 05:32 PM
What a relief! I was contemplating giving up drinking while working on my cars.
Well for a minute or two, anyway.
I Misus Rash'!
Old 03-18-2003, 05:44 PM
Larry, Being a "Dumb A$$" would involve running
the engine and wondering why you had no oil pressure. (Chebby guy drove around one time with
an LS-6 engine for a while until he burned out every rod and main after he did not put one in his engine). Have NEVER forgotten to put the oil
pump drive in BUT only because have seen it done several times by others. As you can see you were
not alone on the board in this mistake.
Agree only possible issues would be dropping it in
the pan on installation and having the same thing happen on distributor removal in the car. Tom V.
Old 03-18-2003, 05:47 PM
Torment's Avatar
Torment Torment is offline
Pump shaft snafu's:
Put one up in a dark garage from under the car, later when attempting to start the engine it spun a half turn and hit a hard mechanical stop Turned out it had missed the hole and was instead wedged between the rear most cam lobe and the block-one junked cam and a bunch more work.
Forgot one just like Larry and dropped it in from the top. Worked like a charm the first time. Later I pulled the distributor for something and while I had it out decided it would be a great idea to run through the valves. Bumped her over and heard a metallic thud as the rod fell into the pan Not fun getting it out with the motor in the car but it was possible.
Lessons I've learned. You band-aid your mistakes now but if you've my luck it will bite you in the a$$ later when you can least afford it
The secret to happiness is not getting what you want but rather, wanting what you have.
Old 03-18-2003, 06:00 PM
Bartman Bartman is offline
After having a OP driveshaft break on me and having to pull the motor to change it I ground the tabs off of mine just in case I ever have one break again.
Bartman
Ponies run but Birds fly
Old 03-18-2003, 06:38 PM
Philcol Philcol is offline
Just did the same thing. Ground mine off too. Just be careful removing distributor. There is an access hole in the back of the block that you can get to and hold the shaft if the engine is out and the the trans or bellhousing is off the block.
Phil
"dreamed I was wide awake........woke up and I was sound asleep"
