Old 02-08-2005, 09:17 AM
SD421's Avatar
SD421 SD421 is offline
Hi,
Could someone post pics of the 62 195 cu in with 4 barrel & linkage(air cleaner off). Ive got a 61 engine in my 62 convertible and it has a funny linkage setup. I was going to convert to a 62 intake & wanted to see how the linkage is set up. Thanks,
Don S.
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
SD421's Avatar
Hi,
Don S.
1966 GTO
KRE Tri-Power
Old 02-10-2005, 10:13 PM
SD421's Avatar
Anyone????
1966 GTO
KRE Tri-Power
Old 02-13-2005, 03:29 PM
Jim Pennell Jim Pennell is offline
Hi Don,
I have a '62 with the 4cyl./4 barrel carb. set-up. I'll gladly e-mail some pics. I'm not sure when I can get to it, but will when I have the chance.
Jim Pennell
Old 02-13-2005, 07:04 PM
SD421's Avatar
Hi Jim,
That would be good to go!
Whenever you can. Thanks!
[email protected]
-Don
1966 GTO
KRE Tri-Power
Old 02-13-2005, 11:32 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Jim, Can ya send me some pics also!!!
[email protected] Thanks!!
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 02-16-2005, 07:12 AM
gwalters gwalters is offline
I would like good clean shots of the linkage setups for all three years (61, 62, 63) for four cylinder 4bbl setups for an article I'm planning later this year. (Greg Walters, Little Indians Chapter - President/Editor) - Send to [email protected]
