O.K here's a simple question for you guy's,how much does a complete 400 engine weigh carb-oilpan??
I want to order some Moroso Trick front springs,but the car currently has a Buick 455 in it,and I'm pretty sure they don't weigh the same,I see they list springs for Camaro only with a Big Block Chevy or a Sm Block,so the question is which ones do I get for my T/A??thanks for any help Rob.. [ August 29, 2002, 04:28 PM: Message edited by: 80pont406 ] |
If you have an all steel car with some power accessories, go with the BB springs. If you have a lightweight car carrying just the motor, go with the small block springs.
Word of caution: Let the car sit for a couple of weeks before you trim the springs. They will sink quite a bit (mine almost sank 5 inches). I know of two guys already that didn't want to wait, and now they have their headers on the ground. [ August 29, 2002, 06:01 PM: Message edited by: Goatman ] |
The car is all steel except for the 4" lift off cowl hood.It will be gettin lightened up a bit pretty soon.What are some ideas to take weight off the front end of the car?It's a 1979 T/A.
Thanks guy's Rob.. |
The front bumper-nosepiece weighs about 398 pounds [img]smile.gif[/img]
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
They both are about 640 thats what I was told awhile back 2nd hand info
Rob, on top of the massive front bumper supports, there are tubular control arms, lightweight brakes, aluminum radiator supports and radiators, fiberglass bumpers, aluminum steering boxes, and good old fashioned hole sawing/plasma cutting that could be done in such a way as to keep the car looking stock, but be really light.
PS Don't forget about the 500lb door braces in those cars. |
Actually, the front end on the 79 is not as heavy as one would think. I've had the inner bumper and frame brackets off myself at least twice and the whole assembly probably weighs between 45-65 lbs.
On the nose of a car, that is 400lbs.
Traditional all iron Pontiacs engines are 640-660 lbs.
![]() SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY! |
80pon406
The Buik 455 was the lightest of the BB's.
https://www.flickr.com/photos/197745168@N07/ "Of all ignorance, the ignorance of the educated is the most dangerous. Not only are educated people likely to have more influence, they are the last people to suspect that they don’t know what they are talking about."Thomas Sowell |
Good morning guy's,
Thanks for all the great info guy's I really appreciate it,one question Where can I find a aluminum radiator support??I would love to have 1 of them,I see Chad Dammen made a tubular radiator support for his T/A does anyone know what he used and what the dimensions were for it??Those boat anchor door bars are definetly gonna GO .
a front racktakes a lot of weight off as do the other things bruce mentioned. the inner bumper and brackets brian mentioned also take a lot of weight off, if any body is interested I am having a front bar made that would replace the steel bumper it will probably bolt on in the stock location and help suport the nose, (my nose is saging terribly after taking the bumper out.) it will also have a tow hook sticking through the spoiler as well as mounts for the turnsignal & hood release. I am also thinking of haveing the entire front nose made out of glass because of the paint cracking. any body interested in these please let me know.
77 Trans Am All Steel, on 10" tires 8.30 @ 165 mph 3,380 LBS Mat it! Spray it! Chute it! Just another 8 Second Pass! |
Bruce is also right about cutting the springs, it happened to me!!sunk 3" in a few days went to move it and the headers were on the ground!
Ray, The 77/78 Nose is about the only nose not being made. If your thinking of making one up, I'm very interested.
Keep me Posted! |
Good info Ray I thought about having a bar made up for the nose also because I know after a while it will start to sag with nothing in there but my car is a 79 though so it's a little different than your's,your idea is a very good one though.Also as for the springs I'll take you and Bruces advice and wait a week or so before I do any cutting.
Thanks for the advice Rob.. [ September 02, 2002, 03:18 PM: Message edited by: 80pont406 ] |
Oh yeah I also took and weighed a 400 complete carb to pan it was 658lbs on my friend scales,just thought I'd let ya know...
Rob, if you have a good stock radiator support, I have a freind that can make you one out of aluminum. They look pretty close to stock when they are done too.
We can have them powder coated or anodized as well.
Goatman that sounds like a pretty good idea I do have a mint radiator support for something like that or do you mean he makes radiator supports out of aluminum?, if thats the case I definetly want one,shoot me a email or something,also thanks for the info on Dick I got a hold of him today I will be bringing a set of heads down to him asap hopefully this month anyway.
[ September 02, 2002, 03:58 PM: Message edited by: 80pont406 ] |
