need headers, (well, just the flanges really) for a 60 389. what other year headers will fit this motor?
Any common D-port header flange will fit. The D-port flange stayed the same for all of the different year ('55 -'79) Pontiac engines, nothing special about the '60.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
b-man is basically right, that the locations of the ports and bolt holes are identical from '55 up, but the height of the port openings in my '58 heads is about 3/16" less than late heads. I don't know what year the ports got higher- if your '60 ports are the small ones, and you're really intent on having original size flanges, I have some pieces you might want, although they're no longer one-piece flanges. I had cut each flange into 3 pieces (front/center/rear) to make lightweight zoomies.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
i may be interested in those pieces. i'm putting a 60 389 in my 31 ford sedan, and need to build my own headers. would you happen to have a pic of what you have?
also, does anyone know if just the flanges can be bought? |
Have you checked with Headers-by-Ed? He used to have a lot of old flange kits available.
I'll try to find some pictures of the pieces i have.
i'll check, but would still like to see what you have. i'm trying my best to build this car without too much off the shelf stuff, ya know?
thanks again for your help |
You've got mail. Jack
My old header stuff weighs 15 lb, plus whatever box I put it in. Let me know.
forsakenfew- I haven't heard back from you; is my mail getting through?
