Old 06-01-2005, 05:31 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/...srcommgrpid=75117251
http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/..._string=&org_string=
  #682
Old 06-01-2005, 06:14 PM
Hattmann68 Hattmann68 is offline
I love this topic. 35 pages and still going hope it goes over 50 when it is said and done. Also George K. gotta be getting rich by now. Chalk up one more post.
  #683
Old 06-03-2005, 10:48 AM
69firebird455 69firebird455 is offline
Any fluid engineers out there???
Anyone know why the vanes on these water pumps are agressivly reverse swept? If you look at the pump from the impeller end the shaft turns to the left (c/clockwise). Most pumps use a neutral or forward swept vane. Seems like the reverse swept vanes would seriously slow the flow down.
Actually, if you think about it, this pump acts more like a screw then a centrifical pump. IMO
So what's the reason behind this????
  #684
Old 06-07-2005, 11:10 AM
Bad Karma's Avatar
Bad Karma Bad Karma is offline
What happened the thread is no longer featured?
Can we get it Featured again. I feel this is a very useful and informative thread
72 Lemans
  #685
Old 06-07-2005, 01:34 PM
dave bolduc dave bolduc is offline
so what you are saying is that there wont be any more HOT running pontiacs????????
ya.ok..............bridge for sale!
  #686
Old 06-07-2005, 01:45 PM
george kujanski's Avatar
And there will be world peace, unlimited petroleum, no pollution, and best of all, NO PARIS HILTON!!!!!!!
George
  #687
Old 06-08-2005, 12:35 PM
cwolf cwolf is offline
Send a message via Yahoo to cwolf
somebody restickey this please
Old 06-10-2005, 03:30 AM
Phil Goat Nelson's Avatar
Phil Goat Nelson Phil Goat Nelson is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by 69Firebird455:
So what's the reason behind this???? </div></BLOCKQUOTE>
I'm no "fluid engineer"....or any other kind for that matter, but maybe this one works by pushing fluid through, rather than pulling it through?
____________________
PhilGoat
  #689
Old 06-10-2005, 06:24 AM
60man's Avatar
60man 60man is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Phil Goat Nelson:
I'm no "fluid engineer"....or any other kind for that matter, but maybe this one works by pushing fluid through, rather than pulling it through? </div></BLOCKQUOTE>
Actually I thought it did the opposite..That is it pulled the water into the "eye" of the impeller and dispersed it from the outer edge under pressure much like a centrifical pump on a fire truck.. The "plate" is used to make sure the water enters where it should..that is why the clearance gap is critical....I might mention that a centrifical pump takes advantage of any incoming pressure and multiplies it. That is what we were taught in Fire Training.....
JMO.
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
  #690
Old 06-10-2005, 07:55 AM
What I see, and agree with 60man:
The pump works by forcing fluid out towards the outer edge (discharge). In doing so, the outlet pressure must be increased also. In turn, a lower pressure area is created in the "eye" of the pump which is a suction to draw fluid from the engine block and the radiator lower hose when the t-stat is open. Since there is a suction on the intake side, which is lower than atmosperic pressure, there is a tendency for the lower rad hose to collapse unless there is a spring inside it to keep it open.
From the vane design, I wouldn't call the vanes "reverse swept". The design is intended to move the fluid out from the eye towards the outside diameter of the wheel. How else would that be done?
George
  #691
Old 06-10-2005, 08:11 AM
George, yea. Impeller shown is correct for throwing fluid.
You all now notice how the Dual outputs are NON-SAME. As if the designer put a preference to water flow into the ___er-side of the engine. My question is: By looking at the pump outlet designs, which engine bank was designated for more flow?
Have a nice day. HIS
  #692
Old 06-10-2005, 11:39 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Half-Inch Stud:
Have a nice day. HIS </div></BLOCKQUOTE>
Nice observation HIS. I can tell you the side that flows more just happens to be the side the heater core draws from. Maybe this is intended, maybe not. There is maybe half the flow coming from the other side of the pump compared to the heater core side! One has to wonder if this reduced flow could cause overheating/detonation on the left engine bank??
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by george kujanski:
George </div></BLOCKQUOTE>
George, Great explanation of how the pump moves water. As far as my statement about the reverse swept vanes, I called the vanes "reverse swept" because on most blowers and water pumps the vanes are straight or they are pitched a bit forward. Like the blower wheel out of your heater core. Look at the vanes and think about the direction the wheel turns. The vanes are "forward swept". This tends to increase velocity as the fluid/air leaves the impeller/vane. On this pump the vanes are "reverse swept" and i would guess that reduces the velocity of the water as it leaves the impeller? Just wondering why they did it that way.
  #693
Old 06-10-2005, 11:53 AM
69: If I remeber correctly, the "squirrel cage" blower wheels used in heaters have the same pitch direction relative to the direction of rotation that the water pump does.
I guess I don't know what you mean by reverse swept.
george
  #694
Old 06-10-2005, 12:06 PM
george </div></BLOCKQUOTE>
George, look at the picture of the pump Mr_GTO posted. Look at the vanes, the impeller turns Counter Clockwise. That means the vanes are Backward Incline instead of Forward Curve. Take a look at the drawing but keep in mind the rotation in the drawing i'm posting is opposite the pontiac pump.
  #695
Old 06-10-2005, 12:19 PM
Well, I'd say it's a forward curve, relative to the actual direction of rotation of the pump. your dwg shows the forward curve rotating in the opposite direction of the actual pump.
I think the important thing is the blade design must be stated in terms of the normal direction of rotation. Based on your dwg, and drawn rotation, I would call the left dwg a backward, the center a forward.
If you take a Pontiac pump and turn it backwards, it would most certainly suction from the outside and pressurize the center. May not be too efficient, tho.
George
  #696
Old 06-10-2005, 10:13 PM
R/ABANDIT R/ABANDIT is offline
I am so glad that I found this post tonight. Because my car has been running at 220 had to put the heat on just to get it home tonight. I'll be tearing her apart tomarrow now that I know what it is. I have a BeCOOL 4 core & a 160 stat & didn't know what to do next. Thanks George.
1977 Trans Am 400CI R/A IV.
**Looks can be deceiving**
  #697
Old 06-11-2005, 04:09 AM
GoatGlider's Avatar
GoatGlider GoatGlider is offline
my humble contribution:
the design of the impellers blades has to do with how quick you want to have the fluid flowing. like the gradient of a screws thread.
speeding up the flow of coolant may help with your heat-problem or not, but coolant needs some time in the radiator to cool down. not too long and not too short.
the cooling system is designed to let the cooland run with a certain speed. not only the pump is relevant, but e.g. the holes from cylinder bank up to the heads or the bypass-hole under the thermostat that is always open.
if you get a bigger radiator, it would make sense to speed up the flow with a more efficient pump. if your cooling system is swamped with dirt, it may help to enforce input pressure. if the pump is out of specs, it should be restored.
however, it needs to find the most optimal flow-speed AFTER you flushed the system clean, have a suitable thermostat and a big enough radiator.
and: my 65 gtos water pump has a divider plate to make sure both cylinder banks get a similar amount of coolant delivered. don't forget that the heater radiator does cool down coolant and therefore compensates the "stolen" amount of fluid for the right bank before giving it back in the right cylinder head.
Robert
my goat and my wife: both are beloved, both are reliable and both are expensive!
  #698
Old 06-11-2005, 04:17 AM
buwalda buwalda is offline
69FB455,
I believe the flow [ and temp ] to both banks is close to equal. I have a friend who has a temp gauge at the front of each head & both gauges read within 2-3 degrees [ F ] of each other. I also believe each bank gets equal pressure. If you look at the pic a few posts back, the pump area outside of the impeller is all open 'territory'; the water can go anywhere it likes, because there are no walls or partitions to divide it, so output pressure would be the same throughout the pump housing after exiting the impeller blades. To create pressure, you have to have a restriction somewhere in the system, which is the thermostat. If you add up the area of all the deck holes for both decks & compare it to the t'stat opening area [ which all the water except for bypass must pass through ] , you will find the t'stat is the restriction in the stock configuration.
  #699
Old 06-11-2005, 01:25 PM
GoatGlider's Avatar
that's an important point: the thermostat opening is quite small indeed and IS the restrictive point.
one wonders why they attach such a fat rubber pipe behind, going to the radiator, if the thermostat does not allow to flow more
removing the thermostat is one of the things i would try to help with a permanent overheating issue. if your engine reaches working temperature anyway, i can't see any reason, not to try this. this increases flow dramatically it will give you a hint, if radiator size or coolant flowing speed is your problem.
and, btw, when flushing the system it helps a lot to remove the thermostat at least temporarily.
btw II: it seems that earlier water pump models like the one in my 65 gto had the divider plate, while later ones had it not. this plate divides the pump area into 2 vertical slices, where the inner one feeds the right bank incl. heater and the outer one feeds the left.
Robert
  #700
Old 06-12-2005, 02:03 AM
LeighP's Avatar
LeighP LeighP is offline
Removing the thermostat isn't the answer...my t/A had its t'stat removed by a previous owner trying to fix an overheating problem....all that accomplished was to not let the car warm up properly, or on a freeway run it would stay cold, then in traffic it would get very hot.
I fixed the problem by replacing the t'stat with a 160 deg one and replaced the non-operative fan clutch...which was the cause of his problems to begin with.
On a side note - after reading this post I was concerned that the new pump I'd ordered with some other parts would be a cast impellor type or not (I'm currently building a 455)....glad to say when the pump showed up it was a cast impellor....brand - "Federal Mogal Carter Pumps" on the box.
And even better, testing the clearance between the new plate and the vanes showed it to be quite close straight out of the box. I've yet to actually measure it though.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
