Old 06-16-2005, 09:42 AM
[email protected] Bob87@intechnetwork.com is offline
Does anyone have pics of a 67-69 firebird with any style of 3rd or 4th gen f-body wheels? I'm looking to upgrade and I'd like to see what they look like with the newer wheels. Also, if you could include how much spacer thickness was required, I would appreciate it. If you don't want to post the pics on the forum feel free to email me at [email protected].
Thanks everyone.
Bob
68 FIREBIRD WITH A 350/TH350 FOR RIGHT NOW. 4 SPD TO COME SOON.
Old 06-16-2005, 10:38 AM
scottk scottk is offline
16x8 3rdgen
225/50/16 front. BS listed as 4.33"
255/50/16 rear. BS listed as 5"
Rear tires kissed a bit on the inside sometimes. Thinner tires might have fixed that. I cut out a pair of old drum faces as spacers. I guess them to be 1/16-1/8" thick. It only kissed when heading uphill into a driveway. I also flattened the tailpipes around the tires.
pleasurizer.com
Old 06-16-2005, 12:21 PM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
Aren't the bolt patterns diferent ???
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 06-16-2005, 02:30 PM
No I don't think so. Just the backspacing.
Old 06-16-2005, 03:22 PM
Mine are 5x4.75
I was told they came from a mid 80s Formula.
GTA wheels and IROC wheels should measure the same for the 3rdgen as the ones on mine in the pic.
pleasurizer.com
Old 06-29-2005, 06:48 AM
poncho1961 poncho1961 is offline
Did you do anything with the lug nuts / studs? I know that the newer wheels are mounted with metric and some of those have a different bevel on the nut / wheel. Had any problems with nuts backing off or anything if you didn't change the studs?
Old 06-30-2005, 12:19 PM
sixt8bird's Avatar
sixt8bird sixt8bird is offline
Here's mine with 1986 Iroc wheels. I used all 4 rears.
