Old 05-19-2004, 09:32 AM
GTO JOE 64 GTO JOE 64 is offline
has anybody tried any of that coolant addative that is supposed to lower the water temp? and if so does it work? Thanks!
Old 05-19-2004, 12:10 PM
Goathead's Avatar
Goathead Goathead is offline
Send a message via AIM to Goathead
All I use is plain water and Watter Weter. It works great...
SIGPIC]http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=139862&dateline=12616 03096[/SIGPIC]
http://www.youtube.com/watch?v=iJrDl3nRNCM
http://www.youtube.com/watch?v=Fvywdocl4GA
http://ultimategto.com/icongraf/65headtitle.jpg
Old 05-19-2004, 02:06 PM
i've not had any luck with the water wetter. we've tried it in different applications and have seen no noticible improvement over a antifreeze mix.
mike
former." --Albert Einstein
- Winston Churchill
Old 05-19-2004, 07:48 PM
Brad B. Hillebrand's Avatar
Brad B. Hillebrand Brad B. Hillebrand is offline
Plain water and one bottle of water wetter works great for me too. 50/50, 70/30 mixes did not work and my 67 GTO came close to overheating..
Brad
Take a ride in my Twin Turbo 63 Lemans.......
http://www.youtube.com/watch?v=Ad8g9IfWxKI
Hot Rod Cover Car -April '07
PHR Magazine Sept.'08
1244HP Pump Gas Dyno @ 11psi (32PSI MAX)
http://s297.photobucket.com/albums/m...ipumpgas-2.flv
Old 05-20-2004, 05:38 AM
george kujanski's Avatar
My personal opinion is that if the magic cooling fluid works so well, the cooling system is marginal to start with.
George
Old 05-20-2004, 07:15 AM
what george said.
mike
- Winston Churchill
Old 05-20-2004, 10:35 AM
I use a RR aluminum, Stewart high flow 180 stat, and flowcooler pump. Brand new engine so no blocked passages. New HD clutch and Pontiac A/C fan. Stroker 400 on pump gas.
Mixes ran temp too high 50/50, 70/30. Plain water and water wetter took temps down to 180 steady.
Worked great for my combo....
Brad
Old 05-20-2004, 11:38 AM
Rugratman's Avatar
Rugratman Rugratman is offline
Will the water wetter keep the corrosion off the parts ?
........I'm just learning as I go.......
Old 05-20-2004, 01:50 PM
Here's a link to some tech info. According to their own data, the biggest benefit is changing to water from a 50/50 glycol/water mix. The water wetter helps either mixture a bit more. Judge for yourselves....
The article also deals with corrosion.
http://www.racerpartswholesale.com/redtech3.htm
George
Old 05-20-2004, 08:16 PM
Funny, I have been thinking about that myself. I tossed out the bottle but I do not think it has any anti-corrosion agents. I was thinking of putting in some Prestone anti-corrosion mix..that should resolve the issue....
Brad
Old 05-21-2004, 08:02 AM
freebird69's Avatar
freebird69 freebird69 is offline
That's some excellent info. I was going to use WW with plain water but since I have AC I now know I need to add some anti-freeze.
