Old 03-14-2004, 04:02 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
OK...so I'm replacing the rear main seal on my 350 with the BOP seal (not removing crank), and I decide to check the rest of the main bearings...at least the bottom halves. I found the #1 bearing scored, as well as crank journal. It will catch a nail on the crank, but the bearing is a bit worse. The #2 and 3 bearings have slight scores in them...just showing copper...the crank looks fine on those. I've had good oil pressure as well. I just wanted it to make it thru this year...at the track. I'll be building a stroker out the 400 I have for next year. What would you do??? I really don't want to spend much $ on it! Can I just put new bearings in it?? I've tried to attach pics. Thanks!
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Jagtec1's Avatar
Darin
9.81 @ 136.39MPH
Old 03-14-2004, 04:03 PM
Jagtec1's Avatar
Here is the bearing...
Darin
9.81 @ 136.39MPH
Old 03-14-2004, 05:25 PM
SCOTT ESTERLE's Avatar
SCOTT ESTERLE SCOTT ESTERLE is offline
I would definately not run it any longer. It looks like the crank will need turned & new bearings. It appears something has gone through the motor. Did you have the bypass blocked off.
Old 03-14-2004, 05:34 PM
wholio wholio is offline
Time for a crank kit.
Old 03-14-2004, 06:28 PM
Jagtec1's Avatar
There will be nothing done with the motor if
I cannot just slap new bearings in it. The 350 was only meant to get me thru this year...guess I'll not be doing much racing, as I really am not willing to dump any $$ into it, and the stroker kit for my 400 is not in my budget at the moment. Maybe I can do a cheap rebuild on the 400 just to run it this season...
Darin
9.81 @ 136.39MPH
Old 03-14-2004, 07:27 PM
goatless's Avatar
goatless goatless is offline
Getting the crank turned isn't that expensive. If you're willing to spend on new bearings and BOP rear seal I'd at least make a few calls to see what the local guys would charge to turn it.
1966 GTO
Old 03-15-2004, 03:52 AM
Jagtec1's Avatar
I will do that...I figured it would be a couple hundred dollars (2-250) to get it turned. I'll make some calls. Thanks.
Darin
9.81 @ 136.39MPH
Old 03-15-2004, 04:35 AM
crazy ray
Guest
Posts: n/a
darien, don't go the cheap 400 rebuild. In the long run it will cost you more. drop the crank turn it and throw in the bearings. and have fun.
Old 03-15-2004, 04:44 AM
Jagtec1's Avatar
Ray...this is for the 350, not the 400! The 400 will sit until next year when I can budget for the stroker kit. I just want to get the 350 together so I can run this year with it.
Darin
9.81 @ 136.39MPH
Old 03-15-2004, 04:45 AM
Jagtec1's Avatar
DOH! I see what you were saying...yeah, I'm not gonna risk hurting the 400 block! I'm not going to cheap the 400 just to get it in!
Anyone have a ballpark figure for getting a crank turned??
Darin
9.81 @ 136.39MPH
Old 03-15-2004, 05:27 AM
goatless's Avatar
I think my guy said $85 for the one he's doing for me right now.
1966 GTO
Old 03-15-2004, 04:42 PM
Jagtec1's Avatar
Wow...wish the shops around here were that cheap. I was quoted $275 to start, and maybe less if the rod journals were OK from one shop, and $185 from another shop. Ughhh. Now I'm not sure what I'm gonna do. I guess it's either pay $300.00 or so, and race this year, or not pay anything and be pissed off. I do have another crank out of the 400...
Could I use it?? Guess I'd need to do some measuring...would I have to do anything to the rods other than replace the bearings??
Darin
9.81 @ 136.39MPH
Old 03-15-2004, 05:49 PM
TTS's Avatar
TTS TTS is offline
If you're pitching this engine soon anyway why not consider cutting/polishing just the main in question? Should save a few bucks anyway. The 400 crank would need a rebalance for the 350 slugs. I think a crank kit would be cheaper/ as cheap as those prices.
A Government big enough to give you everything you want is strong enough to take everything you have. - Jefferson
"If ever a time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams
Right and wrong doesn't need facts all the time.
-Lighthouseman ("lawyer")
Starnes Performance Automatics
www.Starnesperformance.com
Old 03-15-2004, 06:51 PM
Jagtec1's Avatar
I'd think doing it that way would pose a bearing issue...as far as obtaining 1 different sized bearing? A good idea nonetheless. I hope to get the motor to last me to mid November or so...pretty much only at the track, maybe 2x a month. I think I'm just gonna get it turned and be done with it...only $$.
Darin
9.81 @ 136.39MPH
