Old 06-04-2004, 06:48 AM
Paul Spotts's Avatar
Paul Spotts Paul Spotts is offline
prototype block #1 pictured. first step was to fit crank, check all tapped holes, deburr, dry fit etc. I smoothed out and enlarged all oil returns. When spraying wd40, certain areas of the block will retain oil, and of course getting the oil back to the sump is important.
www.spottsperformance.com
East Coast Pontiac engine builder - still going strong
4 month waiting list
email [email protected]
1981 Trans Am 455 w/6X heads 4 speed 4 wheel disc (for sale)
1969 Trans Am clone 9.79 at 139 so far
1964 Banshee clone project - Opel GT platform
Old 06-04-2004, 06:53 AM
all work is prior to machine shop - decks were not cut yet
pictured here is dip stick hole I tapped with 1/4 npt to plug - using Canton pan with external dip stick provision
Old 06-04-2004, 07:03 AM
pictured next is the large bore head gasket in place. This particular block had the coolant holes repaired, not an issue with the production run.
so far - so good
block was sonic tested and bores have plenty of meat with 4.350 bore. there was core shift, though and allpontiac is addressing that issue as well. Keep in mind this block is a prototype and all minor issues are being addressed. Of the 3 blocks being tested, all info is being compaired and addressed - pretty impressive - gotta love what these guys are doing to get a quality product out there.
Old 06-04-2004, 07:36 AM
Ron's Avatar
Ron Ron is offline
Paul will this block be available without the cooling holes?
Due to the current economic conditions...the light at the end of the tunnel has been turned off.
Meet you at the finish line.....don't be late!
Old 06-04-2004, 08:34 AM
Ray Cox's Avatar
Ray Cox Ray Cox is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Ron:
Paul will this block be available without the cooling holes? <HR></BLOCKQUOTE> THAT WOULD BE WAY COOL!!!!
8.30 @ 165 mph 3,380 LBS
Old 06-04-2004, 11:45 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Thanks for the pics and info Paul.
Still waiting for the Butler iron block for my new 535" engine, however. Hopefully not too much longer!
Regards,
"455HO" Lloyd
Old 06-04-2004, 10:24 PM
SupergasDil's Avatar
I knew Butler was woking on the Aluminum block, but was unaware of a new iron effort. What is the difference between the IA2 and Butler Iron?
Paul, That looks sweet. I want one.
Old 06-05-2004, 04:07 AM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Excellent pictures and insight Paul. I checked the block sample out at VMP, as well as the 2 cross sections of old vs. new. Pretty impressive...that is the amt. of time and effort put into getting it right. I love seeing the thought and procedure that goes into the prep and testing...
I learn something new every day!
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 06-05-2004, 05:44 AM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
Ron,
The answer is yes, I asked that question in the VMP Pictures post. http://forums.performanceyears.com/g...=399104926&p=2
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
www.bopengineering.com
Old 06-05-2004, 07:12 AM
Brian Baker's Avatar
There is no "new" Butler iron block that I'm aware of, but I believe Butler still has a stash of IA-I blocks.
Old 06-05-2004, 07:23 AM
Lloyd-TX's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Brian Baker:
There is no "new" Butler iron block that I'm aware of, but I believe Butler still has a stash of IA-I blocks. <HR></BLOCKQUOTE>
Brian:
I've spoken with Jim on several occasions concerning their new aluminum AND iron blocks. Three iron blocks HAVE been cast, but they want to finish R&D and testing on the aluminum block before releasing the iron blocks for sale.
My engine builder believes that an iron block is better suited for my purposes.
I hate to step on any toes, but Jim has told me that the alloy in their iron block is FAR superior to the IA2 alloy and that each Butler iron block will be subjected to a "seasoning" process prior to shipping.
Regards,
"455HO" Lloyd
Old 06-05-2004, 08:49 AM
Rob Rob is offline
Would be something for the Butler's to produce a Cast Iron Pontiac block too! On the alloy statement, what is FAR SUPERIOR to excellent? I'm going to offer Cryogenic option for seasoning on the blocks I sell but I doubt anyone will find any material bonus from KRE, JPB, or All Pontiac.
I can say that IA/Dick Duclowe years were strong usuable blocks, IAII is well revised very, very good looking and will most likely be the first one available to the public. KRE's casting looks great, but machining hasn't been done. Haven't seen JBP's alum block in person but the pictures that were posted of the casting last year look really good and dynoing to 2900hp is a obvious sign. Don't know about the JBP plan for date of release to sell cast iron or aluminum.
-Rob
Old 06-05-2004, 08:50 AM
Wade,
I read that SOME of the holes were not drilled but not all of them so some plugging of the deck would STILL be required.
Do you agree or did I read that wrong?
Karen, I really like your new hair style!
Kenny looks like he is chubbing up on your good food cooking. Starting to look like me! LOL!
Old 06-05-2004, 11:34 AM
Tom,
This is a quote from TA Bob "All of the water cross overs will be blocked on the out board side of the head surface. The builders will transfer the holes that best meet the holes in the head being used."
I guess I took that as they would be cast, shut. I also had a conversation with Rob that if they were 5/16 that they could be opened further or plugged easily. So now I'm not sure.
What I can tell you is that mine were a PITA to plug as some were overlapping and required a very large hole to cover completely. I spent a weekend with a magnetic drill, a large selection of resharped end mills to find tap drill sizes, and pipe plugs
Wade Congdon
BOP Engineering
Old 06-05-2004, 12:18 PM
Rob Rob is offline
I believe this is one of the few things not completly revised on the IAII blocks.
I'm pretty sure several of the holes are what holds and locates the patterns when the block is poured. They become water holes, I'm pretty sure set up in stock locations. There are a couple of places where a second machining operation made end mill type cuts on one or more of these holes which I believe Bob and Frank already have worked on with Roush(probably the area where Wade had a deck plugging adventure). When the bore becomes siamese and 4.300 plus, o-ringing has always been a creative excercise(I would figure eight the wire ring for the two center cylinders and adjust the outers to stay out of water holes. Regular head gasket fire rings end up on top of stock placed water holes.
Not sure how Bob and Frank plan to offer the deck as many people want dry decks, many want plenty of cooling water holes, and others custom. I proposed a 5/16 hole in the same area of stock locations which is the drill size for 1/4 inch pipe plugs making life easier before decking. They may do much of the plugging and decking operation or leave it up to the individual engine builder. Many of us can handle the deck in any configuration, but if a private individual gets a block for street car type stuff, it would probably be best if they had a easy set of water holes and simple headgasket.
So what this long winded post boils down to is water holes on big bore blocks will need to be smaller for sealing. This will require water hole plugging of the casting before decking and then machining the water holes or not(dry decked).
-Rob
Old 06-05-2004, 12:26 PM
Robert C.'s Avatar
Robert C. Robert C. is offline
Yes we are plugging the out board holes. The casting holes have to be where they are now. We are no longer drilling them for the gaskets, because the bigger bores sizes make the gasket water holes to close to the bores. So until we have a gasket to fit the best head out there we are plugging holes or not drilling any. It is easier for you to drill then plug.
Now the upper holes that are cast are placed in a good location. We are not drill the three 5/16 water holes. You will have to drill them too. They will be a breeze to plug if needed. Again the head that is use will determine where to drill. We did this because the big horse power users ask us to do this. It saves a lot of their time and money if we did it.
Freeze plugs are now threaded holes. We are supplying them with the blocks. We added about 1/16 to each side of the main webs to completely cover the steel main caps. This adds even more strength to the main area.
About the metal: We are using the highest grade of Cast Iron that has the best strength and cylinder to ring sealing capabilities. To hard of casting material will cause early ring ware. There is a fine balance as to what you can use.
Inspection of the production blocks is running longer because we had to get special electric NDT (None Destructive Testing) equipment made to check the wall thickness. Because of the high grade of casting material that we use, a 5MHz (Megahertz) transducer will not measure the right thickness. We will not send out blocks until we are sure that we have the best block that can be made period. We are doing what you asked us to do, Do it right or don't do it at all.
Bob C. / Frank G.
AllPontiac.com
Bob C.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads
Boss Bird Funny Car
Best pass to date 08/06/2016 [email protected]
Allpontiac Big Chief Aluminum Engine Block
http://www.AllPontiac.com
Old 06-05-2004, 01:47 PM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> We are doing what you asked us to do, Do it right or don't do it at all. <HR></BLOCKQUOTE>
Thank you.
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 06-05-2004, 03:57 PM
Thanks Bob for the extra info.
Looking forward to seeing your block at Norwalk.
The threaded water jacket plugs I hope are aluminum with an "o" ring on the plug that seals against a machined surface?
Old 06-05-2004, 03:58 PM
Rob Rob is offline
Just when you think it can't get any better; registered mains and threaded freeze plugs!
5 megawatt tranducer? Those blocks singing when you check them?
-Rob
