Old 05-12-2004, 10:18 AM
GOATKEEPER2 GOATKEEPER2 is offline
does anyone know the correct cc for the 1963 326 heads (548232). thanks
Old 05-12-2004, 10:47 AM
jusjay's Avatar
jusjay jusjay is offline
Both the 260hp and 280hp motor used the same head. 1.92/1.66 valves and 68cc.
Jay
Old 05-12-2004, 12:01 PM
Poncho_Villa's Avatar
Poncho_Villa Poncho_Villa is offline
Hey Jay, While you are on the topic of this engine. Do you know if these two engines used the same camshaft also? Thanks, Rick
Old 05-12-2004, 02:59 PM
Thanks for the reply, that'a what I thought but I wasn't sure
Old 05-26-2004, 09:59 AM
johnta1 johnta1 is online now
Poncho_Villa, I believe they used the same cam.
Old 05-26-2004, 09:25 PM
Thanks John, I was just a bit curious as to the difference between a 326 HO and a 326 with a 2 barrel carb. Obviously the induction, but thought maybe the HO would breath better with more lobe lift and duration from a factory cam. Do you know if the HO came with duel exhaust? Rick.
Old 06-18-2004, 12:08 AM
bmpmdf bmpmdf is offline
Hmmm, I though the HO engine used a little more camshaft too. At least mine will when it goes back together!!!
Have A Great Day
