Old 10-30-2004, 01:23 AM
Formula400NYC Formula400NYC is offline
Im looking to convert my 71 Firebird to HEI. What do I have to do? Its a D.U.I. distibutor, if that helps. thanks........Jerry
Old 10-30-2004, 05:15 AM
Formula8's Avatar
Formula8 Formula8 is offline
Replace the entire ignition wire with a 10ga wire going to the "Bat" or "Ign" terminal of the HEI cap. Make sure you have a full 12-13 volts at that terminal.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 10-30-2004, 07:56 AM
Chris C Chris C is offline
The wire he is talking about comes from the starter. Sometimes people replace the stock coil setup for an HEI and don't replace the wire. They get lower volt readings and the distributor won't work as well.
Chris
Drink Beer.
Old 10-30-2004, 11:25 AM
a73formula a73formula is offline
Do you know what color the wire is?
Old 10-30-2004, 11:57 AM
I just looked at my wiring diagram. It looks like the wire that goes to the coil is yellow. I remember mine being black though, maybe my memory is mistaken. There is also a red and a purple coming off the starter. The red goes to the alternator and the purple goes to the fuse box.
Drink Beer.
Old 10-30-2004, 05:25 PM
soupman soupman is offline
Couldn't you use the red one going to the alternator? As soon as the ignition is turned on, doesn't full voltage go to the alternator and the HEI?
Old 11-01-2004, 02:36 PM
Soupman, thats what I was thinking too. Does any one know for sure ? Thanks for all the help.
Old 11-01-2004, 03:08 PM
If I remember right I think you need to run a fuse if you o it that way or the car will stay idling after you shut it off because it is getting constant voltage from the alternator.
Old 11-01-2004, 03:34 PM
george kujanski's Avatar
Typically the standard system has two coil wires: the first is for starting, usually yellow, and comes from the ignition switch IGN2 terminal on "A" bodies, OR the "R" terminal on the starter solenoid for "F" bodies. THe wire for power when running is a resistance wire that ultimately comes from the IGN1 terminal on the ignition switch. For HEI use, bypass the resistance wire with a 12 Ga. wire; leave the yellow wire where it is, i.e. the two wires come together at the HEI BAT terminal.
You can't use the alternator output wire, it has battery voltage all the time. If you connect to that, your ignition will be on all the time; really bad for gas mileage
Geo
