Old 02-27-2004, 06:40 PM
redfirebird redfirebird is offline
I have a 1995 Bonneville with 180,000 plus miles. I have owned the car since new. I just started having problems. When driving at a low speeds the car just stops. It has also done it a few times while stopped at a traffic light. When I try to restart the car it turns over several minutes before starting. I thought the fuel filter may be bad and changed it but that was not the fix. When the car stops it does not sputter or anything it just stops and I get a check gauge warning. I am considering buying an OBD II tester but was hopping for some advice first.
Thank
Keith
Thank
Keith
Old 02-28-2004, 07:44 AM
Pontiacmuscle's Avatar
Pontiacmuscle Pontiacmuscle is offline
Send a message via Yahoo to Pontiacmuscle
Keith; Get the trouble codes out of the computer; use a scan tool(maybe you can borrow one) and see if there any set and also most good scanners have a "live action" mode so you can see what your sensors are doing...i.e. oxygen sensor etc. This should help you narrow down and pinpoint the cause. Let us know what happened.
Josh
ARROWHEAD ADDICTION: An incureable disease contracted from the pointed edge of classic pontiacmuscle; all consuming, taking over mind, body and soul.
Old 03-04-2004, 10:54 PM
TIAUTOMAN TIAUTOMAN is offline
ONE of 3 things
Crank sensor
Ingiton module
PCM
Has the water pump leaked recently?
When the car shuts off do you have spark?
Injector pluse?
Old 03-07-2004, 08:08 PM
The water pump does not leak and I never checked for spark the cars starts with-in a few minutes. One thing I have noticed it only stops running at low speeds 30 and under or when stop like at a traffic light.
Old 03-11-2004, 06:50 PM
MOST likely the crank sensor
but you need to check for spark and injector pulse when it dies.........To make sure
CODES?
Old 03-12-2004, 06:39 PM
I think I will just replace the crank sensor. Can't cost too much and hopefully not too difficult to install
Old 03-29-2004, 09:58 PM
96bonneville 96bonneville is offline
Please let me know what you find. I have a 96 Bonneville doing the same thing except my check gauge warning light does not come on so nothing is written to computer. I changed fuel filter and fuel pump checked out OK. I would really appreciate knowing what you find causing the issue
Old 03-30-2004, 04:31 AM
I replaced the crank sensor I also replaced the harmonic wheel. I must have tweaked it a little when removing it. Car has not acted up since.
