Old 04-22-2004, 07:40 PM
Tim Corcoran's Avatar
Aren't you supposed to get oil coming up through the pushrods when you prime the engine by turning the oil pump with a drill motor? I always saw oil coming up from the pushrods on to the rockers with other motors I have done? I am getting plenty of oil pressure while I prime the engine. Also the rockers look like oil is getting baked on them, like they are getting too hot. Experienced engine builders please give me feed back.
Tim C
Tim Corcoran
Tim C
Tim Corcoran
Old 04-22-2004, 08:23 PM
SupergasDil's Avatar
Hi Tim,
No pro here, but the last injun I primed got nothing up to the top on prime. I oiled the heck out of everything with a bottle. As soon as we fired her up there was plenty coming out of the pushrods.
Old 04-22-2004, 08:44 PM
Jim Zeek's Avatar
Jim Zeek Jim Zeek is offline
If its on a stand try turning it over a few times. I did mine last night. Solid roller with T&D rocker shafts. Took about 10 minutes to get oil to all of the rockers. Once they started oiling, no problem getting it back up.
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial
http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1
Old 04-22-2004, 09:41 PM
Doug Christie's Avatar
Doug Christie Doug Christie is offline
Mine took a long time to get to the top, a good ten minutes or so. Maybe need more rpm on the drill.
"For some reason a glaze passes over people's faces when you say "Canada". Maybe we should invade South Dakota or something."
Old 04-22-2004, 09:50 PM
kidgoat kidgoat is offline
Jim is definately on the right track. Prime with a drill for a minute or two, then rotate the crank an eigth turn or so, prime a few minutes, then keep doing that. Sometimes the lifters need to go up and down before oil will want to come out of them. The whole procedure may take a half hour or so. -Jesse
Old 04-25-2004, 09:32 PM
72firechicken 72firechicken is offline
I had a similar problem with my motor. Although I was running solid flat tappet lifters and no oil was going to the top and what I found was defective lifters and all the oil was just running out from around the top plunger and I still had decent oil pressure, the lifters were lazer brand lifters, total crap.
Old 04-25-2004, 09:34 PM
Also I did run the motor just to see if the rpm would help it oil while using some stock rockers and it burned and marred them up almost immediatly.
Old 04-26-2004, 06:57 AM
Armadillo Armadillo is offline
Before I installed the lifters I also let them sit in quart of oil for a few days to get them primed up. That helped get oil to the top of the engine right away.
Old 04-27-2004, 03:56 PM
67cruiser 67cruiser is offline
Remember Pontiac dis. turn opposite direction?? you going right direction?? opposite from say corporate engines?? chevy?? ect???
Old 04-27-2004, 07:09 PM
You are turning it counter-clockwise?
Sometimes it takes a while. Try the aforementioned turning it over several time w/ the valves in different positions.
