73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 10-28-2003, 08:53 PM
64tempest 64tempest is offline
Im pretty sure that a tilt coloum from a 73-77 G/P
will fit my 74 LeMans but would like to know for sure before I hit the bone yard soon. Is this correct or is there somethingelse I need to look for ?
Old 10-29-2003, 06:07 AM
Many of the "73-77" GrandPrix tilts have the upper bowl with the plastic pod mounted on the lh side. Often these thin plastic "pods" are deteriorating. If you want a tilt with the smooth style upper bowl, might watch for a tilt out of a '73-77 Regal, Cutlass, or Monte. The latter all used a dimmer switch mounted on the floor, like your LeMans, & if the turn signal harness is the same, you will not have to swap the one out of your straight column.
Old 10-29-2003, 07:26 PM
Thanks OPH
Its been a while since I had one of this body style. I now remember my Can Am hadthe g/p dash anf the coloun was a bit different. Its amazing what you forget and suddenly remember once youve been reminded!
