Old 01-01-2004, 08:27 PM
wheelspin's Avatar
Question: Need a driver's door for a 68 GP. Will 68 Catalina or Bonnevilles interchange?
Thanks for any info
Les
66 GTO Coupe,455/trips,700r/2500stall,12bolt/3.08,1.79/13.01/104.5
68 GP daily driver and 2004 Route 66 Tour participant under restoration
Better lucky than good
Les Iden
wheelspin's Avatar
Thanks for any info
Les
Les Iden
Old 01-02-2004, 03:03 PM
68 Prix 68 Prix is offline
From what I seen the doors would interchange from either car. I will check and post either later today or tomorrow. Try Steve at Pontiac Heaven he had a 68 GP in there last time I checked. www.Pontiacheaven.org , Good luck if you need any other help on locating parts or information on your car let me know. Pat
[This message was edited by 68 Prix on January 02, 2004 at 05:17 PM.]
Old 01-02-2004, 03:48 PM
From what I can tell from my Fisher body manual, as long as it is an open top door it will interchange. I know that the Catalina and Ventura use a different inside door handle style than the GP and Bonneville. Hope this helps. Pat
Old 01-02-2004, 03:56 PM
wheelspin's Avatar
Pat,
Thanks for your quick response. I e-mailed Steve, which would work out nicely since I plan on racing @ his Phoenix event in April and could pick up the door then.
I am restoring this car for the GP Chapter "Cruise Across America" in early May. We plan to drive to Tulsa and join the westbound cruise there. Any chance of you making part of the Cruise, or did I ask you already?
Les
Les Iden
Old 01-02-2004, 09:30 PM
I don't think I will make that cruise. I will have to let you know when it gets closer to that time. Take care Pat
Old 01-02-2004, 11:02 PM
Steve Barcak's Avatar
'68 Prix- thanks for the referral. I do have a '68 GP. I think the Bonne/Cat door may be different as they have vent windows and the GP does not. The skin is probably the same but, the inside mounting and/or structure may be different. anyway, I'll check..
Les, sorry about what happened to your car. Steve www.pontiacheaven.org
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 01-03-2004, 11:19 AM
wheelspin's Avatar
Thanks Steve, you have mail.
Les
Les Iden
Old 01-03-2004, 09:37 PM
pontiacrod pontiacrod is offline
Wheelspin you have mail
SitDown, Shut Up,and Hang On!
Old 01-05-2004, 02:29 PM
Steve- I like to give referrals to guys I had good dealings with.
I did think the doors might be different with the wing windows but it just does not show enough in the Body manual. I read some place that wing windows were available on the GP in 68 but never found that to be true.
The door inside door handle is 68 only, and specific to the GP and Bonnevilles.
I love the 68 GP but it is a bear to find parts when needed.
Old 01-06-2004, 08:46 PM
CompTA28 CompTA28 is offline
Hello, this is the first time I'm posting on these
forums. Sounds like you need to find a nice GP door, the Cat or Bonney will have a wing window and you can't have one side different from the other! Did the window survive? That glass is all special too with the GP logo in glass. These 68's
have many one year only parts and are hard to find. Luckily mine was mostly all there when I found it. I see another 68 GP is right down the road from me in Brookfield. I'm in Sheboygan.
Dan B.
95 CompTA
77 Cat
73 Formula
68 GP
90 GMC 454 Dually
Dan B.
95 CompTA
77 Cat
73 Formula
68 GP
90 GMC 454 Dually
Old 01-06-2004, 09:34 PM
wheelspin's Avatar
CompTA#28,
Welcome to the Forum from a fellow 68 GP owner.
I think I have a door located, but appreciate any leads you might have. Window and internals are good.
Les
Les Iden
Old 01-11-2004, 10:38 AM
Coach's Avatar
Coach Coach is offline
I'm not sure of the '68, but I just installed the trim and glass on my '67 GP. On the'67 the door skins, both inside and out, are the same for the cars with or without vent windows ( Cat, Bonny, and GP). There are sets of holes for mounting either window track set and of course the vent frame. It is actually a good case of GM engineering, by using the same door it reduces the need to press two different sets of doors, instead just set up the tooling to press out all the holes you might need either way.
Hope this helps,
-harry
1967 Grand Prix Convertible Project
Sold - 1967 Grand Prix Convertible ( http://forums.performanceyears.com/f...d.php?t=639110 )
2003 Bonneville coupe (hers)
2007 Avalanche LTZ 4x4
Old 01-11-2004, 11:28 AM
wheelspin's Avatar
Harry,
Thanks for the input. I think I located a straight original door in Phoenix @ Pontiac Heaven thanks to Steve Barcak.
Les
Les Iden
Old 01-17-2004, 04:06 PM
Les did you find a door for your GP? Also Do you need any other parts?
Pat
Old 01-17-2004, 07:11 PM
wheelspin's Avatar
Pat,
Thanks to your suggestion, Steve Barcak came up with a fender and door which I will see next week. If these parts are workable, then I will have what I need for the restoration. I will post some pics after the GP is finished. I appreciate your help.
Les
Les Iden
Old 01-18-2004, 09:29 PM
Les,glad to hear that.
