Old 12-17-2004, 09:44 AM
bobkatsvb bobkatsvb is offline
I've got a 64 GTO with a 400ci motor, 670 heads, power steering, and a 4speed. I'm looking at either Hedman, or Hooker Super Comp 1 3/4" headers. Is one better than the other? Is there something else I should be looking at? I'm on a somewhat limited budget. Thanks.
Old 12-17-2004, 10:38 AM
Ron's Avatar
Ron Ron is offline
If you want cheap, will probably leak, a real biotch to install and will hang down low so every speed bump or dip in the road you will ding them then purchase Hedman or Hooker.
Otherwise purchase a set of Doug's Headers that will be easy to install, won't leak, increase your performance, and will tuck up close to your floor boards and look good for many years.
Due to the current economic conditions...the light at the end of the tunnel has been turned off.
Meet you at the finish line.....don't be late!
Old 01-12-2005, 10:43 AM
fdowdy fdowdy is offline
Don't hold back, Ron
Thanks for the heads up.
Hmmm.. Now WHERE did this part go???
