Old 11-22-2004, 04:29 PM
Schurkey Schurkey is offline
Sorry to bother you for such a basic question.
I'm wondering what you can tell me about the Pontiac (Not Chevy) 265 engine. I guess it was produced in '80/'81. Is it a low-deck like the 301? I have heard that it has only four main bearings. Is this true, and if so, is the crank 'n' block machined for the fifth bearing, or is it rough cast? Which bearing did they "forget"?
I don't recall ever seeing one of these, and if the 301 isn't popular, the 265 isn't even on the radar.
Thanks, all.
Old 11-22-2004, 05:08 PM
Trips4me's Avatar
Trips4me Trips4me is offline
Send a message via MSN to Trips4me
Never heard of a Pontiac 265... They made a 287. The 301 is a one-off engine. Not too many folks put time or effort into the 301's although there are some who have.
1965 GTO Hardtop - Fontaine Blue, Blue interior, 389 Tri-Power, 4 speed, 3.36 posi, Rally I's
Old 11-22-2004, 06:53 PM
Blue '66's Avatar
Blue '66 Blue '66 is offline
I have heard of the 265,not sure how related they are.They are definatly not related to the traditional pontiac motor. I just know what I have heard are @#%#&@! words!
The Following User Says Thank You to Blue '66 For This Useful Post:
Old 11-22-2004, 07:11 PM
Stuart's Avatar
Stuart Stuart is offline
Yes, the 265 is a low deck block like the 301, from about the same era. I don't know about how many main bearings it has. It definitely is a LOW performance engine.
Old 11-22-2004, 07:37 PM
Trips4me's Avatar
OK.... you guys got my curiosity up now. When did Pontiac build these 265's and what did they put them in??? I guess I learned something new today.
Old 11-22-2004, 08:05 PM
MalteseFalcon's Avatar
MalteseFalcon MalteseFalcon is offline
If I recall correctly, the 265 was the base engine in the Formula in 1980 or 1981.
Steve
1978 WS6 W72 4 Speed Trans Am - Martinique Blue on Light Blue - Fire Am Restification Project
1972 4-Speed 455 HO Trans Am - Original Cameo White on Blue car - Restoration Project
Old 11-22-2004, 08:15 PM
Blue '66's Avatar
Very early 80s.I believe they were optional in the mid size B-O-P cars.Put out a whopping 120hp
That's not bad considering the Olds 260 had about 105hp
My parent had a '79 cutlass salon w/a 231,after alot of engine trouble I found a olds 260 from a '78 cutlass to put in.The front end sat at least 1 inch lower but the car would bark the tires(slightly)This was my first V8 to drive and then I graduated to a 389 in '82
Old 11-22-2004, 08:52 PM
tom s tom s is offline
I think the 265 was a 56 engine.It was a short deck motor,had 2 1/2 mains and 3in stroke.Maybe Steve can verify.Tom
Old 11-22-2004, 09:11 PM
CUBIC INCHES: 265; BORE(inches):3.75000; Stroke(inches):3.0000; Main Dia.(inches):3.000; Rod Dia.(inches): 2.250
It's usually mentioned in the same breath as the 301 and it seems a lot of parts interchanged.
Steve
Old 11-22-2004, 09:19 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Yes they did make a 265[4.3L]. They came in GP`s also. The only
engine that is more pathetic than the 301.
Old 11-22-2004, 09:49 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
265-- 80 & 81 only!! Base V-8 engine in the Firebird/ Formula, Optional in the LeMans, GrandPrix, Catalina & Bonneville. 3.75 bore X 3.00 stroke 8.3 to 1 compression, 120 hp @ 4000 rpm, 205 lb ft torque, 5 main bearings.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 11-23-2004, 11:30 AM
bmpmdf bmpmdf is offline
Want to make a 068 cam sound big? Put it in a 265 with 1.65 rockers! Still no power though. 80-81 only, thankfully.
Have A Great Day
Old 11-23-2004, 03:05 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
They make the best Boat anchors!
Not worth the cast iron they were made of!
Drop in a 350-455 and have fun!
Try calling CRUSHPROOF! 512-386-9889
Old 11-23-2004, 06:31 PM
Dont bad mouth the little engines. I worked for Pontiac when they were new. No they were not performance engines but they ran well and gave good mileage. Put one it my 1961 Chevy PU when the 389 gave out. It gave me years of dependable service even when pulling a small trailer. Because of the head design they are not worth trying to hop up.
Old 06-18-2025, 05:32 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Resurrection time.........the Pontiac 265.
Just saw this on Ebay.
https://www.ebay.com/itm/296340261591
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 06-18-2025, 07:41 PM
Buddy's parents had tge 265 in a mid-80's car...buick wagon?? Anyways. No replacement for displacement. 301 for the win.
Disclaimer: well i'd never go below 455, maybe 400, okay maybe 350 these days.
Old 06-18-2025, 08:29 PM
As many on this board know,I have built some serious HP with a 301/383 stroker engine.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
Old 06-19-2025, 05:02 AM
I recall seeing one in a car back then and did not believe the owner that it was a 265 until I looked at the underhood emissions label and saw that the battery was in fact on the driver's side of the car.
Old 06-19-2025, 05:06 AM
Tom S here's A list of Pontiac production cid motors up to 59 when the 389 came to be.
287
317
347.
Old 06-19-2025, 09:39 AM
I know them well,I used a couple 347 cranks with cut down mains in a couple of my 303 SCCA stroker builds.Tom
