Old 10-02-2004, 10:43 PM
Jeff R's Avatar
Jeff R Jeff R is offline
My car is supposed to have Bright Blue Standard interior. I know the interior was redone sometime in the past since it's got '72 Standard door panels and the rest is '70 Custom interior. When I got the car it had no headliner or sunvisors installed although there was a new headliner with the car's spare parts and it does match the rest of the interior. Everything matches closely, just a bit brighter than the Lucerne Blue exterior. I need a new package tray and sunvisors and I've got color samples (supposedly '70 Bright Blue) from various sources including PY, but none of them match what's in my car. None of the samples match each other and they are all condiserably lighter and grayer (almost washed out looking) compared to my interior. Is my interior indeed Bright Blue, or are the package tray and sunvisors supposed to be lighter than the rest of the interior?
The left is the color of my interior and the right is one of the samples.
Jeff R's Avatar
Old 10-03-2004, 05:41 PM
soupman soupman is offline
You definetly have bright blue. The sample on the right looks like my blue interior in my 71 T/A.
Old 10-04-2004, 04:59 PM
racerboy's Avatar
racerboy racerboy is offline
I agree. That looks like the same Bright Blue as my 70 T/A.
Frank
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 10-04-2004, 05:09 PM
racerboy's Avatar
pic of my interior
Old 10-04-2004, 08:05 PM
weranc55's Avatar
weranc55 weranc55 is offline
Whats up with that shifter knob? I have the same one in one of my 70's. Is it a factory one or aftermarket. Mine seems like its been on the car forever.
Old 10-04-2004, 08:46 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
The Hurst cueball shifter was factory on some late 60's GTO but never the 2nd-gen F-body. The factory shifter was simulated leather(rubber) in the same shape as the automatic knob but had an raised aluminum insert and shift pattern emblem.
The cueball shifter was very popular in the 70's so you see a lot of cars with them.
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 10-05-2004, 01:16 PM
Jeff R's Avatar
OK, so I definitely have Bright Blue. Has anyone here had to replace their Bright Blue sunvisors or package tray, and if so where did you find them? PY and Classic are definitely out of the running as they're nowhere near the right color.
Old 10-05-2004, 01:54 PM
Dirty70Bird Dirty70Bird is offline
My 70 also has the brigh blue interior. If I remember correctly, the package tray looks like the color on the left, as shown above. Performance seamed to be the only place that had the bright blue listed in their descriptions. I think I got my package tray from Ames, but like I said, its the wrong color.http://www.hbci.com/~chriss/PhaseSix/LeftFrontSeat.JPG
http://www.hbci.com/~chriss/PhaseSix/RearSeat.JPG
Old 10-05-2004, 07:10 PM
WOW, Screwed that reply up. I meant to say, that my package tray looks like the color on the right ( the dull blue) and I got that one from Ames. Classic was the only company that I saw that had the bright blue package tray. I only noticed this after I had the wrong color in mine.
Old 10-06-2004, 11:04 PM
Gordy Doyle Gordy Doyle is offline
Don't trust Classic. They list everything in their catalog and then supercede and consolidate part numbers and ship you what they have. If you call them on it, they act like the items sent will work fine. With them you're lucky if the part even fits a firebird (that is, if it doesn't also fit a camaro).
Gordy
Gordy
73PF455TH4003.08:1
Old 10-13-2004, 01:35 PM
Resto70 Resto70 is offline
You should try contacting SMS auto fabrics in Washington I believe. They can send you headliner material samples and if they provide a match of the color they can make the visors for you. They were able to help me with orignal headliner fabric and matching visors in red for my 70 Formula.
Old 10-17-2004, 07:08 AM
When I requested samples from Year One (I hated to) but they sent one that was real close to bright blue. Might want to check them out.
