Old 11-02-2004, 03:47 PM
az67goat's Avatar
az67goat az67goat is offline
Does the base coating discolor much upon use? I understand that it is a ceramic based coating. I'm trying to decide if the $160 for the full ceramic is worth it.
Has anyone used the band clamps that PYPES sells? They look nice. Assuming that you wouldn't want to weld ceramic coated pipes.
Thanks.
az67goat's Avatar
Thanks.
Old 11-02-2004, 04:07 PM
TUNNEL PORT's Avatar
TUNNEL PORT TUNNEL PORT is offline
The Ceramic coating wont discolor at all under normal use on the street or track. Unless you break in your cam & the tubes glow red hot at that time. Then the coating will turn dull.
I broke in the cam on my Boat & about 8"'s of each of the tubes turned dull. I took a product called "Header Chit" to it & it returned it to glossy again.
My opinion is that the coating is a good thing to have. Because if it was just paint I would have had to repaint them, but it would have just burned off again anyway.
Ron
Old 11-03-2004, 10:27 AM
meanolgoat meanolgoat is offline
The Pypes Band clamps are excellent. Summit sells a different brand that work as well. I highly recommend them if you are not welding your system.
Old 11-03-2004, 10:10 PM
disc0monkey's Avatar
disc0monkey disc0monkey is offline
breaking in a cam will dullen them, but they are purdy
Old 11-03-2004, 10:22 PM
another
Old 11-03-2004, 10:24 PM
again
Old 11-03-2004, 10:26 PM
btw make sure the motor is level before you start dropping it in saves time
Old 11-03-2004, 10:27 PM
the clamps are descent i guess, im welding everything but the tails this winter
Old 11-03-2004, 10:31 PM
yup
Old 11-04-2004, 10:40 AM
az67goat's Avatar
Thanks Monkey. Great pics. I guess I still am not sure about the base coating yet. If you don't order ceramic coating, the standard headers come with a coating that is discribed as "ceramic based", according to PY.
Does anyone have any experience with this standard coating? Doug's used nickel plating in the past as their standard coating.
Old 11-04-2004, 11:05 AM
8point 8point is offline
Send a message via ICQ to 8point
Az67goat, I have Dougs with the standard coating , Have only run the motor about 90 minutes (20 break in 70 tuning things up). the coating still lookes new , no discoloring. During breakin it got hot enought to boil over just as it got to 20 minutes.
Jim G.
Old 11-05-2004, 08:10 AM
az67goat's Avatar
Thanks 8point,
If you could, let me know how they look after a little more running time.
Old 11-05-2004, 11:56 AM
PonchoMike's Avatar
PonchoMike PonchoMike is offline
Running the base Doug's on our '65, been on since early this spring and have not discolored one bit. Also used band clamps on our system, didn't want to weld it, they're not cheap, but worth it.
"What's the matter numbnuts, didn't your parents pay enough attention to you"?
Old 11-06-2004, 06:11 PM
1gr869's Avatar
1gr869 1gr869 is offline
I called Dougs because someone mentioned that the warranty would be voided if I put them on with a fresh rebuilt motor. The guy at Dougs was very nice and said it won't void the warranty but it "may" discolor the headers during break in and they won't take them back if that happens. I think the extra money for the coating is worth it. I was told it will help keep things in the engine compartment cooler. I still have not decided wether to put the old exhaust manifolds on or take a chance on the new headers. I hate the thought of trying to put them on afterwards (the hassle) but I also hate to discolor them cuz they are so perty! No pics to share..yet. Still putting the motor back together.
Old 11-08-2004, 06:11 AM
cujo cujo is offline
With the Pontiac engines you can hardly see the headers unless you are under the car. That is why I will be going with the standard coating and wrap the headers with insulating wrap to help keep the engine compartment cooler and improve the exhaust flow.
Old 11-08-2004, 06:41 AM
cujo,
Look at the warranty, it states;
"Any type of heat wrap applied to the header or exhaust piping will void this warranty"
& that is for both coated & not coated.
Ron
Old 11-08-2004, 09:55 AM
That is good to know. I have not purchased the headers yet. What does the Doug's Header warranty protect you from? What do you think they are worried about as far as the heat wraps are concerned? If it's just a cosmetic finish warranty it would not really matter to me since the headers are going to be wrapped up anyway.
Old 11-08-2004, 02:57 PM
don't wrap em, even the "uncoated" ones come with some sort of coating and wrapping them i heard will make em rust.
