View Poll Results: Poll question
$300 68 61.26%
$350 33 29.73%
$400 10 9.01%
Voters: 111. You may not vote on this poll
Old 05-23-2004, 12:41 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I`m with JC455 and Ken. Street Chief and Strip
Chief sounds good.
  #62
Old 05-23-2004, 12:49 PM
tom s tom s is offline
Dave,I will have a 446ci KRE headed motor on the dyno in about 3-4 weeks if you want to do some compares.Tom
  #63
Old 05-25-2004, 05:34 PM
The Holley intake I have flowed modified by SD perfromance flowed great. I would like to see a slightly bigger plenum and maybe the runner lengths extended a little, and carb pad blended into the tops of the runner better. It is a good starting point.
  #64
Old 05-25-2004, 06:07 PM
MoJo's Avatar
MoJo MoJo is offline
Sounds good Skip, now stuff it under a 2nd Gen Formula Hood.
"Pocahaulass"
""Guitar groups are on the way out", "The Beatles have no
future in show business"
Decca Records rejection of The Beatles - 1962
  #65
Old 05-25-2004, 09:47 PM
69GPModJ 69GPModJ is offline
I'm inspired again...
Chief HaulAss
Chief B-Bye
Chief So-long
Chief Hauls-Ass
Chief WOT
Thunderbolt
ThunderQuad
Quicksilver
HellRiser
Air Demon
69GPModJ
Moderation in everything--including moderation. WC Fields.
  #66
Old 05-26-2004, 02:43 PM
Junkyard Dog's Avatar
I am with Diamond Jim, who is making the 290 cfm D-port?
Badder than old King Kong
-Jim Croce
  #67
Old 05-26-2004, 03:51 PM
Big Injun's Avatar
Big Injun Big Injun is offline
You "dog" you. This is your clue...LOL
Dave "Big Injun" Anderson
[email protected]
www.4mypontiac.com
For GTO Celebration items click the tile coaster.
  #68
Old 05-26-2004, 05:19 PM
slowbird's Avatar
slowbird slowbird is offline
Is there a date set yet that you hope to have the the intake available by? When will you start engine testing (comparing intakes) with it and have some results?
  #69
Old 05-26-2004, 05:20 PM
slowbird's Avatar
Could the head be BullDOGs?
  #70
Old 05-27-2004, 06:32 AM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Woof-Woof, Is it Summer Yet?? OK Who has more info, price etc. -WWW.bulldogperformance.net/Pontiac.html
  #71
Old 05-27-2004, 07:37 AM
PONTIAC DUDE's Avatar
Ken & Dave:
Would be serious about trying your intake on my 1976 500 cu.in. plus ATI Procharger set up if it flows those #'s and comes in around the same height as the Holley Street Dominator for my ATI ProCharger blow thru applications. With the hat and the taller Victor intake, kinda makes it rough to use a stock type appearing hood. You know that stealth mode.
Kinda hard to make blow thru power when your restricted to the Firebird hood lines.
E-mail me info and Keep me informed.
  #72
Old 05-27-2004, 08:41 AM
Ken -Ace- Brewer's Avatar
Ken -Ace- Brewer Ken -Ace- Brewer is offline
Send a message via Yahoo to Ken -Ace- Brewer
I hear ya Dude. That is the whole reason for this Intake. Making it stealth so it fits under the hood but flows good #'s. We are trying to have it ready before x-mas! This would be a great stocking stuffer It should sell for around $285.
The heads will come in 3 different versions. The "Track" version will have 2.19 x 1.75 vlaves. The "Street" version will have 2.15 x 1.75 vlaves. And the 350 head will have 2.09 x 1.68 valves. I also have prices but they are at the shop. Watch for my new add in HPP!! It will have pricing and more! Also we are giving the website an update! Check it out soon!
Be Cool,
Am I glad I got out of the business I was in? HELL YEAH!!!
  #73
Old 05-27-2004, 09:32 AM
Torker II and Holley both short. Torker II has a big plenum.
  #74
Old 05-27-2004, 09:51 AM
slowbird's Avatar
Ken Brewer: What is your web site address? Id like to check it out.
  #75
Old 05-27-2004, 04:19 PM
PHILLYGOAT PHILLYGOAT is offline
http://www.pacificperformanceracing.com/index.html
http://ourworld.cs.com/GOAT490/myhomepage/auto.html
It looks GOOD, runs FAST, just SMOKES so much it is EMBARRASSING to drive!!!
  #76
Old 06-26-2004, 08:46 AM
briann briann is offline
So is this intake going to be "exactly" the same height as a stock iron unit? I have no hood clearance as it is now with my 455 HO alum intake on my ned generation Formula. I need to ru na holley anda 1/2" nitrous plate and this new intake might work, or if the height isnt right the pads will work fine for nitrous nozzles instead.
  #77
Old 06-26-2004, 11:32 AM
Big Injun's Avatar
It will be stock height. This is the largest segment of the market.
[email protected]
www.4mypontiac.com
  #78
Old 06-26-2004, 12:41 PM
I would pay a hundred bucks extra to have it 1/2"-3/4" lower than stock height! or at least have enough carb pad material available for someone to mill it down that much for added hood clearance.
  #79
Old 06-26-2004, 04:56 PM
Quotes:
"I like the "Tomohawk" or "Tomahawk" not sure how its spelled intake manifold.
Apache would work too.
According to many, the Street Dominator is/was the best flowing street manifold ever produced. Rodney Butler ran a modified Street Dominator on his 9 sec "street" car with a spray bar built into the plenum. Much of the new intake is being based upon the Street Dominator with many improvements like the removal of the heat riser/egr passage to keep the air charge cool...and of course larger runners that flow big numbers."
Hey Dave!
I know a guy who used to work for Holley, who now works
for Ford Engineering, who worked on that intake.
He also worked on the Pro Dominator Tunnel Ram Intake.
A lot of dyno time was used to make the Street Dominator intake BETTER than any factory Ram Air 4
intake by several percent.
I agree that it would be nice to have a lower profile,
BIG runner intake that you could use with a blower carb set-up.
Ken, You want to try a Torquer 1 intake with all rear
runners I had built on Lady Dudes car at Norwalk this year?
  #80
Old 06-26-2004, 06:01 PM
Also if it was 3/4" shorter carb pad than a stock intake I could run the ATI Procharger hat with my stock formula hood. Now that would be cool.
