Old 05-03-2002, 06:05 PM
94bville 94bville is offline
I have a 94 Bonneville with 105K. It has been a great car!
In the last few days the cruise control has gone out. There is no activity at all. I turn the unit on and press the "Set" button at speed and nothing happens.
Is there any diagnosing I can do with a VOM to verify that the unit is getting power, switch problems, etc.
I hate to buy a new control unit (or something equally expensive) until I know absolutely what is wrong.
Any help would be most appreciated.
Thanks,
Mike
Thanks,
Mike
Old 05-04-2002, 09:29 AM
try adjusting the brake switches. they tend to fall out of adjustment after a while.
as far as testing with a dvom, most of the parts are solid state and you can't test them accuratly in my experience.
if you can find a gm service manual there is a section with function tests listed. if yours has vacuum lines running to the control under the hood make sure that you have good vacuum to them.
mike
former." --Albert Einstein
- Winston Churchill
