Old 03-01-2001, 08:14 PM
Max Max is offline
I have a 70 Lemans. I want to upgrade the fuel line to 1/2in. Does anyone make a 1/2in. pick-up that fits into a stock gas tank?
Max Max is offline
Old 03-01-2001, 11:46 PM
randy randy is offline
Max, I also have 70 LeMans. Going to 1/2 seams pointless because there is still 8inches of 3/8 pickup tube in the tank.You can pull only as much gas as a 3/8 tube will allow. The pickup tube is connected to the main fuel line, which is also 3/8, by a rubber gas line.The stock fuel pump also takes a 3/8 line. Are you building a faster motor that requires more fuel?A good working stock fuel pump will supply you with plenty of gas.
Old 03-02-2001, 09:32 AM
you can drill out the factory pickup and resolder 1/2" line into your origional unit. mike
former." --Albert Einstein
- Winston Churchill
Old 03-12-2001, 01:15 PM
HANDSEL HANDSEL is offline
I have a 72 Lemans and installed a sump in the stock fuel tank and as electric fuel pump and use 1/2" line all the way to the fuel pressure reg. It works great!
Old 03-18-2001, 07:59 PM
Max Max is offline
Thanks everyone for your input. I ended up drilling out the 3/8 line out of the stock and welding in a 1/2in. line.
