Old 03-27-2005, 06:21 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
I just lost my header virginity to a pair of Hookers. I have a 67 Convertible Firebird and I just finished the install of my first pair of headers and it came out great. The headers are a set of Hooker Super Competition ceramic coated part #4107-1 and a Flowmaster exhaust system part #17104. The headers were a little tough to get the bolts started but once I did it want easy. They fit like a glove. Nothing hits, the oil filter comes off with no problems and the starter has plenty of room. They are a little close to the steering box but it shouldn't be a problem. The only problem I had was the spring that attaches to the clutch throwout fork. Where the spring attaches to the frame the header was in the way so I made up a new catch for it and mounted it to the back of the starter. Problem solved. The exhaust system required some cutting down but that was no big deal either. This system uses a crossflow muffler that tucks up in the wheel well like factory so ground clearence is not reduced. It states that it will not work on convertibles but that is because to the floor X brace. I will shim it down later. It looks like the front has to drop about 1 1/2 inches and the back should be fine where it is. The only thing I'm not to sure of is the way the tail pipes sit. It would have been nice if they were chrome. I'm not sure what I'm going to do with them yet.
Pictures of install.(6 total)
67 Firebird Convertible
jwcfbd's Avatar
Old 03-27-2005, 06:22 PM
jwcfbd's Avatar
Old 03-27-2005, 06:23 PM
jwcfbd's Avatar
Old 03-27-2005, 06:24 PM
jwcfbd's Avatar
Old 03-27-2005, 06:25 PM
jwcfbd's Avatar
Old 03-27-2005, 10:24 PM
455earlybird's Avatar
455earlybird 455earlybird is offline
Looks great still looking for a system for my 67 bird. Can you put chrome splitters and run out the side. It should dress it up if you like the look.
67 Firebird Best time 1.53 60' [email protected] 1/4 [email protected] 1/8 3500lb. leaf springs
Old 03-28-2005, 08:25 AM
jwcfbd's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by 455earlybird:
Looks great still looking for a system for my 67 bird. Can you put chrome splitters and run out the side. It should dress it up if you like the look. </div></BLOCKQUOTE>
Thanks,
The pipes exit out below the 1/4 panel so I think putting any thing on them would look bad. In the instructions it tell you to cut the intermediate pipe 2 1/4 inches and that is why it hangs down so far. I guess that's what I get for following directions. If you go with this system cut to fit your car. I may go back and cut the tail pipe so it fits inside the 1/4 panel and then put a down pipe on it.
Old 03-29-2005, 10:56 PM
jwcfbd's Avatar
Today I was able to drive the car to work. All I can say is WOW. The system sounds great and the power increase is incredable. I am very happy with this setup.
Old 04-01-2005, 08:02 AM
jjs jjs is offline
I have a 69 fb, would like to know what exhaust system you used. From the pictures it looks like you have frame connectors, What brand name are they. I thought frame connectors could not be used with convertibles?
Old 04-01-2005, 08:58 AM
jwcfbd's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by jjs:
I have a 69 fb, would like to know what exhaust system you used. From the pictures it looks like you have frame connectors, What brand name are they. I thought frame connectors could not be used with convertibles? </div></BLOCKQUOTE>
The headers are a set of Hooker Super Competition ceramic coated part #4107-1 and a Flowmaster exhaust system part #17104. The subframe connectors are from http://www.globalwest.net/. They really made a difference in the way the car feels in the turns. I plan on putting the factory body pan back in I just need to get some spacers.
Old 04-01-2005, 08:59 AM
jwcfbd's Avatar
subframes
Old 04-25-2005, 02:27 PM
jwcfbd's Avatar
I just finished redoing the tail pipes. I really didn't like the way they came out when I installed the system to begin with so I redid them. Here is what it looks like after a lot of cutting and some help from a local exhaust shop that expended the cut pipes for me.
Old 04-25-2005, 02:31 PM
jwcfbd's Avatar
the new tail pipes
Old 04-25-2005, 02:32 PM
jwcfbd's Avatar
rearend
Old 04-25-2005, 05:31 PM
68FB400's Avatar
68FB400 68FB400 is offline
JWCFBD
Tail pipes look 100% better!!
I see you're in Hall County, I'm in south Forsyth. I'd be interested in talking to you about your headers.
Wayne
[email protected]
Old 04-25-2005, 05:59 PM
firebum firebum is offline
Jwcfbd,
Great system, nice installation! I am about to install Hooker Comp Headers on my '75 Camaro and my son's '72 Camaro. I bought the Pypes 2 1/2 header-back X-pipe sytems with the Pro-V Mufflers. Thought we would test out these systems on the Chebys before we put them on the Firebirds and the T/A. I'll let everyone know how everything works within the next week or so.
One question...I can't seem to find the subframe connectors on the Global website...Probably EA (early Alsheimers).
Thanks,
Jim
1973 Trans Am 4-Spd 455, #'s Matching
1973 LT/RS/Z28, 4-spd, 28K Milies, #'s Matching
1972 Camaro 4-Spd
1975 Camaro
2000 C5 Coupe
Old 04-25-2005, 10:06 PM
jwcfbd's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by 68FB400:
JWCFBD
Wayne
[email protected] </div></BLOCKQUOTE>
Thanks Wayne,
Just let me know and we can get together some time or email me at [email protected]
Old 04-25-2005, 10:08 PM
jwcfbd's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Burt:
Jwcfbd,
Thanks,
Jim </div></BLOCKQUOTE>
Jim,
http://www.globalwest.net/ From the main page go down to GM click on Camaro/Firebird 1967-81. Scroll down to the parts list and the subframes are the third item in the right column.
Jim
Old 04-26-2005, 11:36 AM
Thanks Jim, I'll check it out.
Thanks,
Jim
1972 Camaro 4-Spd
1975 Camaro
2000 C5 Coupe
