Old 03-07-2003, 09:02 PM
Forrest's Avatar
Forrest Forrest is offline
hey I have a 72 in dash tach, it has a two prong plug at the rear, it came out of a 72 gto with the unitized ignition, the other tachs pre 72 without unitized ign. have only one wire for the tach, when i hook it up ( the one wire to the neg. side of the coil) on my 70 gto it works but is reading about 500 rpms too high, I`m not sure what to do with the other wire (pos. or neg hook-up?), I have all the assembly manuals for 70`s and up but they all only show for the single wire tachs even the 72 books with schematics, what to do? please help, can i get this 72 tach that was for a untized distributor to work on a points type distributor? all the other tachs I`ve seen only have the one wire type tach? thanx
Forrest's Avatar
Old 03-11-2003, 06:32 PM
Jack Blum's Avatar
Jack Blum Jack Blum is offline
The single wire tach is most likely from a 6 cylinder car. That I am afraid that it just won’t work on a V8 without serious modifications. The 6 cylinder distributor puts out 6000 pulses/minute at 2000RPM (2000 / 2) * 6 It’s divided by 2 since the distributor turns half the RPMs of the motor, multiply by 6 because there are 6 pulses per rotation of the distributor), where a V8 puts out 8000 pulses/minute at 2000RPM. The difference being 8000 – 6000 = 2000 pulses/minute. Now reverse the math, (2000 / 8) * 2 = 500 RPM added to the reading. As for the 2 prong plug, id say one is the same tach pulse as the single wire tach and the other is a ground or possibly a light, but id be guessing. Good luck.
TigerEFI.com (Classic Pontiac Fuel Injection) [email protected]
Motto: Build it for NASA and drive it like you stole it!
2004 GTO Company car, 1994 TA 25th Anv, 1971 Grand Safari Wagon, 1968 GTO EFI, 1968 GTO Stock, 1968 GTO Convertible in desperate need of restoration.
