Old 04-06-2003, 09:26 AM
67rs6spd 67rs6spd is offline
help id some part #'s please.Rear axle cmg0662g cmg is posi firebird whats the rest?
distrib#1112191
carb 7043265 JH0603= 4 barrel fb manual whats the 2nd half?
trans p3c08b sice cover 7 bolts tapped holes for shifter arms.
top block # c569387 ZZ I know the ZZ is 73 ta 455 whats the 1st part c is month and the rest is?
4x heads id # right 1253 left id# a183
rally 15x7 jj inside by valve stem m53 HM
tag ST 73s87
tra 236 a51 75 75
o3d ws4
050187
Thanks for any help.
distrib#1112191
tag ST 73s87
tra 236 a51 75 75
o3d ws4
050187
Old 04-06-2003, 11:54 AM
Held for Ransom's Avatar
Let's see...
CMG 066 2 G...CM(3.42:1 Posi-traction)G(Chevrolet Gear & Axle) 066 2(date code, 66th day of '72) G(Chevrolet Gear & Axle)
7043265 JH 0603...704365('73 4-speed carb) JH(bin identification. Workers buiding the car, using the build sheet, found it easier to look for a two letter code than a seven digit code) 0603(date code, 60th day of '73)
P3C08B...P(Muncie) 3(year, '73) C(month, March) 08(day) B(close-ratio)
(569387 ZZ...(569387(it is actually a parenthesis that starts the Motor Unit Number) ZZ(455 w/4-speed)
Head numbers...try to reread right side, left looks close A183(date code, January 18, '73)
Rally II rims...could be original, M5 3(year, '73) HM(code, 15x7 Rally II on A-, G-,and F-body) missing is the two sets of numbers on both sides of valve stem to date code even better
Next part you're missing info
ST 73 S87...ST(style) 73(year, '73) missing (2F)S87(Firebird 2DR H/Top Coupe) missing...N(plant manufacture) 123456(sequencial body number, NOT part of your VIN) BDY(body number)
TR 236 A51 75 75 PNT...TR(trim number) 236(standard interior, black) A51(strato bucket seats) 75 75(paint code, Buccaneer Red upper and lower) PNT(paint code)
03D WS4...03D(date code of body, 4th week (D) of March (03)) WS4(Trans Am)
050187...Fisher Body coding of some sort
So long, farewell.
Old 04-06-2003, 06:23 PM
johnta1 johnta1 is online now
Good job Held!
I wonder if the 1253 should be I253?
But that would be a stretch for the date codes for each head. Jan to Oct?
johnta1
Old 04-06-2003, 07:58 PM
held for ramsom thanks for the great info I'll double that head and the cowl tag #'s maybe I miss read the rear # if cmg is firebird 73 then maybe that 0662 is realy 0663 I'll have to doudle check after this latest snow 6-12 inch.Any luk on that ditrib #1112191?
Old 04-06-2003, 08:41 PM
1112191 is the distributor for the ZZ engine and XE engine (found in G-, A- (excluding station wagons) and F-body 455/automatic). It too should have a date code next to the number like 3A20 (last digit of the year, letter designation for the month and two digits for the day).
I believe the CM code was used for many years of the F-body cars.
Mistakes I typed above...
carburetor number should say 7043265
N(plant manufacture) should say N(plant manufacturer, Norwood, OH)
[This message was edited by Held for Ransom on April 06, 2003 at 11:58 PM.]
So long, farewell.
Old 04-07-2003, 12:03 PM
UPDATE:
after examining my TA's rearend I've come to realize that the second set of numbers (CM G 066 2 G) is maybe a shift designation. Dating rearend can be done by looking where I've pictured below.
So long, farewell.
Old 04-07-2003, 01:17 PM
Held for ramsom thanks for the rear update,date code.I will get the other numbers when the snow melts.
Old 04-11-2003, 02:26 PM
held for ramson rear date is C23.Numbers on rim are M5 3 HM.Alternator 1100927 37amp 3C19 is 1973 March 19th? Full tag info
ST 732FS87N092788
TRA236 A51 75 75
03D WS4
050187
I double check the right head it is I253,is this date to far out to match.This seems to be the only number on the car that does not date match?What do you think?
Old 04-12-2003, 08:40 AM
Did your rearend casting have another digit?
The date coding of the rim is shown below, looking on both sides of valve stem for numbers...2(Feb) 26.
You have dated your alternator correctly.
The 'A' in TRA (second line of trim tag) is throwing me as I've never seen it.
The head number is off, but the car might have had a problem early on and was fixed by a dealership.
All other numbers seem to indicate a numbers matching TA.
So long, farewell.
Old 04-13-2003, 06:33 AM
I'll take a pic and post it.
