Old 06-22-2002, 12:48 AM
temp pest temp pest is offline
This is driving me nuts .. I am trying to bleed my brakes after having the lines off . I can't get nay fluid to come thru the rear wheel cyl.s . I now know I have fluid as far back as the junction of the hard line to the rubber hose thats bolts to the top of the diff. and splits to each wheel . I removed the lines to the cyl.s and the bleeder nuts & I bought a MityVac today.
Tryed the Vac on the bleeders and the holes for the lines . Not even air will pull thru . Whats up here ? Do i need to disassemble the rear brakes and remove the Cyl.s and inspect them or what ??
Thanks in advance
Andy
Thanks in advance
Andy
Old 06-22-2002, 06:11 PM
STripleduce's Avatar
STripleduce STripleduce is offline
Get new bleeders.
Old 06-23-2002, 12:05 AM
Thanks .. Seems the inner rubber plungers were pushed all the way in , there wasnt as much B fluid in there as I though and the seals froze to the inside of the cyliners .. The hose on the Diff is fine , I think it was colapsing under Vacumn and had dirt also.
Man , I thought i cleaned all that stuff.
Installed speed bleeders all around too ..
Andy
