Old 09-08-2002, 02:01 PM
74redgto 74redgto is offline
I have an header leak on my 4x heads. I have felpro gaskets. I am not removing the headers only loosing enough to get the new gaskets in. Cutting them in 3 pieces and doing each seperately. 2 Questions. 1. Does the softer feeling side of the gaskets go against the header flange and the smoother side against the heads? 2. Should I use some kind of sealant on the gaskets?
Hoping to have this done by the second half of the Chiefs game so help is appreciated...
Old 09-08-2002, 09:12 PM
Rob B's Avatar
Rob B Rob B is offline
Now that the game is probably over this might not help. If you have a set of headers made for your car, I am assuming a 74 GTO, its a fairly simple car to pull them all the way out and make sure that your surfaces are totally clean, if not clean them. I've never used the fel pro gaskets, alway used the Mr Gasket premium ones with the high temp copper sealant. never had a problem with them leaking after I started using that on my d-ports. Now I have e-heads and didn't used anything on them and so far no leaks or blow outs.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 09-08-2002, 11:08 PM
Unfortunately it isn't over. I solved the middle flange leak by installing new gasket and using the red high temp silicone sealant. BUT, front passenger flange is still leaking. I did the same, didn't get a good seal, I then worked to place another gasket doubling the effort. Still I have a leak. Tomorrow will remove today's efforts and will try again fresh. If it doesn't work then will have to remove the headers. They are not impossible to work with, especially on the passenger side, but they are all the trouble I want, especially with a lot of other repairs waiting.
Thanks for the suggestions, ALL are welcome.
Old 09-09-2002, 06:48 AM
rickschabener's Avatar
rickschabener rickschabener is offline
What brand headers are you using and how old are they?
Rick
Old 09-09-2002, 10:26 AM
Believe they are hookers, they are old...I know, go buy a new set...BUT, I will be putting a new motor in the spring with e-heads and already have new headers for the new motor. Can't afford to buy a new set for a few months.
Old 09-09-2002, 11:44 AM
Only reason I asked is because I had an old set of cheap cyclone blackjack headers on my car and they would not seal no matter what I did. The header flange surface was warped and extremely rough. They were never machined smooth.
Rick
Old 09-09-2002, 02:42 PM
Rob B's Avatar
If you think you have problems now and your switching to e-heads in the spring.... Your going to love installing your new ones on the drivers side!!!!!
What brand did you buy and what size pipe/collector?
If you already have them and they are the hedmans1 7/8" 3 1/2" made for a 69 firebird, I'd seriously think about sending them back and getting a custom set made or talk to Scott Esterle at Summit.
Apparently he has had Hedman make custom 1 3/4" with 3" collectors that will fit a 74 ventura (GTO) for some of their customers but I don't know how good they fit.
I'll inform you NOW that you will Bitch, Cuss, Moan, and Bitch again and again if you have the Hedmans for a Fbird. They WILL hit the motor mount (modify the mount), They WILL hit the starter, and they WILL hit your gear box and your steering knuckle, thats with manual steering. If you have power steering
I wish I would have had a set made, it would have been well worth the extra cost for them for the time I spent making the ones I had fit. I was not impressed at all with the workmanship of the bends of the Hedmans. Thank God I didn't spend the money to get them coated! Now the passenger wasn't so bad, it's a 2 piece design on the set I have and takes a little finagaling to get them together.
Old 09-09-2002, 09:12 PM
Scott has already taken care of me on the Hedmans that are suppose to fit without all of the headache. Won't know til spring if they work. I honestly don't remember what brand headers I bought 20 some years ago, But the people who have had the car the last 15 years didn't change them. Gives an idea of what they have done with it. Worked all day trying to seal it, sealed 2 gaskets together, still no good. Leak stopped in the front of the flange but still coming through the back. Think I will try our forsale section on this site for used.
Old 09-10-2002, 09:24 AM
Rob B's Avatar
I had a set of hooker super comps 1 3/4" That were in perfect shape that I sold last month for $100. That is one of the best fitting headers you will find for that car with d-ports! Good luck in your search.
Old 09-10-2002, 10:06 AM
Well to cheaply get by, I just order the walker's from Spotts Performance. They said they would clear the power steering, guess I'll know in a couple of days.
Old 09-10-2002, 10:12 PM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
while you have the headers out, get a file or something to get all that hardened stuck on gasket material off your heads. In my experience its what is stuck to the heads that cause the problem, and it will just ruin new gaskets real fast if left there.
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 09-10-2002, 10:39 PM
Great reminder, thanks 428. I used some sand paper to try and remove gunk from heads and headers, but wasn't successful. I am in a time crunch to get it done, but at the same time going to take the time to do it right. Will make sure the new headers have a good mounting surface.
Old 09-11-2002, 11:02 PM
RRF RRF is offline
I have an old article from HPP around here called "Header Headaches" or something, that gave a step by step process for installing Hooker Super Comps. It involved placing the gaskets on the heads, marking and trimming off the excess gasket, transferring the trimmed gasket to the headers, and then cutting the unnecessary header flange between the primaries.
I could scan it and email it to you... if you're interested.
Old 09-11-2002, 11:34 PM
I very much appreciate the offer, but I am going to leave the flange complete if possible. The ones I have seperate tube flanges, they have been nothing but trouble. Would like to see if the full flange aids or hurts.
Again though, thanks...
Old 09-12-2002, 02:54 AM
428GTO70's Avatar
Yeah I also tried to use sandpaper but it didnt work on the tough crap, I went to sears and got a fine straight flat file and it took all the stuff off the head and my manifolds very easy, only had to drop out the bolts and was able to run the file on the surfaces quite easily.
Old 09-12-2002, 06:51 AM
My old, cheap headers would never seal. I installed super comps on my 68 Firebird 3 months ago. I also removed the flange between the primaries. They seal great! The only thing that appears to make a difference is a thick flange and a machine tooled mating surface.
Rick
Old 01-30-2003, 06:28 PM
PONCHOMAN PONCHOMAN is offline
I always use the tin exhaust manifold gasket that felpro sells and I have never had a header leak at the head.
Old 01-30-2003, 08:59 PM
DAVE RIBEIRO DAVE RIBEIRO is offline
Something you need to try on new or old is
using double gaskets and keep tightening the headers bolts..In many cases that's what starts
the problem in the first place..They come lose and create a leak, then you have already ruined the gasket..Keep the bolts tight and you will have
no-problems??? good luck..Dave 1033/stock
Old 01-31-2003, 12:47 AM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
I use Permatex Ultra Copper on both sides of the gaskets befroe installs, and then tighten up the bolts. My old Hedmans have been on the car for 8 years now with no leaks. And, I do not have the outer bolts.
One trick though is to install the headers, and then every time you drive it, let it cool down completely, and re-tighten the bolts. Keep doing this until 3 times in a row, none of the bolts move. The gaskets shrink a little with the first days of heating and cooling. That's why they come loose at first.
TIGER EFI - Electronic Fuel Injection for the Traditional Pontiac Engine. [email protected]
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
