Old 06-14-2005, 12:02 PM
68LeMans_ger's Avatar
68LeMans_ger 68LeMans_ger is offline
Can anyone tell me, how the 68 front arrowhead is attached to the bumper? I can't figure out if these are screws or some kind of bolts. Do I have to take the bumper off to replace the emblem? Are there any additional spare parts I need?
Thanks,
Dan
68 Pontiac LeMans
Thanks,
Dan
68 Pontiac LeMans
Old 06-14-2005, 12:30 PM
Verdoro 68's Avatar
It's attached with threaded studs on the back of the emblem. No need to pull the bumper, you just have to carefully pry it off.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 06-14-2005, 01:07 PM
newtoGTO newtoGTO is offline
Verdoro_68, are you indicating the studs are only "pressure fitted" onto the bumper and no nuts or rubber attached to the arrowhead studs?
John
Old 06-14-2005, 01:47 PM
1-GTO's Avatar
1-GTO 1-GTO is offline
Send a message via Yahoo to 1-GTO
I thought there were nuts on the back side of the arrow head emblem that have to be taken off,then pry the emblem off or wiggle it out?
GTO.....Gran Turismo Omologato,True Pontiac Excitement!
Old 06-14-2005, 07:37 PM
Verdoro 68's Avatar
Yes, at least on the two Enduras I've taken apart they were pressure fit.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 06-15-2005, 08:29 AM
fyrebird68's Avatar
fyrebird68 fyrebird68 is offline
Yep, the arrowhead is just jammed in there! Came that way on two bumpers I have. There's not even an access hole in back to get to any kind of nut that might hold it on.
Bob Trimpe
68 GTO ragtop
91 T/A
69 XKE
Old 06-16-2005, 09:00 AM
Thanks to all, I will try to pry it off. Hope I don't ruin the paint around the emblem...
68 Pontiac LeMans
Old 06-16-2005, 12:02 PM
Endura: pressed into the rubber. So rock&lift it out.
68Chrome: nuts on the other side need unspun.
Both fine-Q Arrowheads avaiable from PY (I know for sure).
Old 07-13-2025, 11:28 AM
Karan77 Karan77 is offline
Default Hii
If you're replacing the front arrowhead emblem on a '68, make sure you get the correct size and mounting style—some are adhesive-backed while others require hardware. The reproduction ones can vary in quality, so look for OEM if possible or a trusted aftermarket supplier. Clean the surface thoroughly before installation to ensure a strong bond. It’s a small detail, but it really helps bring back that classic look and finish. Totally worth the effort for any restoration project!
Old 07-30-2025, 02:04 PM
I've removed them with two pieces of thin fishing line, one looped from each end top and bottom.
