Hello fellow Poncho-philes
I'm in the middle of a rebuild on a stock AFB off of a '67 400 (it came out of a Bonny). I want to use it on my 326; I also have a factory manifold for it. In addition, I have an AFB off of a '66 389 GTO that I'm using as an "example" for when I reassemble the choke, secondary and throttle linkages. I will also "can" the throttle cable adapter off of this carb to replace the ball-stud used on the Bonny. I have torn the carb down *completely* and I need to find a source for the special screws that hold the throttle and choke plates to the pivot rod. Anyone have a recommended source for stuff like this? Also, some jetting questions: I have an AFB "strip kit" that will allow me to modify the primary and secondary jetting and the step up rods. Since this is a smaller engine(less air drawn thru carb, I figure I will need to go a bit leaner on the pri and sec jets and step up rods. What would be a good ball park initial jetting setup? I know, I shudda gotten a Q-jet manifold and carb.... Thanks for any help you folks can pass along. ------------------ Mike '67 Tempest Custom Post Coupe
Mike |
Mike |
Mike, try Jon Hardgrove at the Carburetor Shop in Missouri. 573-392-7378. He also has a website at www.thecarburetorshop.com. Ames Performance also sells his rebuild kits, which include most of the screws if you get a level 2 kit (I don't recall if the throttle plate screws are included). I can't give you an answer on the jetting, but Jon can probably get you close. Bear in mind that he will probably tell you that using a carb from a different engine will require all kinds of internal recalibration (bleed sizes, etc.), but I think you can get close enough with jet and metering rod changes. Jon occasionally posts on this board as "Carbking."
------------------ Larry '63 421SD LeMans... in pieces in my garage and basement
Larry '63 421SD LeMans... in pieces in my garage and basement |
FYI~ I once bought the AFB rebuild kit from Ames: the throttle-plate screws were NOT included in that kit. If you must have new screws, find a machine shop in your area and if they don't have them, if they're nice enough they can tell you where to get them. Good luck!
66Bronz - there are two levels of the kits, the second level does in fact contain the throttle screws, and LarryF - you are correct about the airbleeds. Jon.
------------------ Good carburetion is fuelish hot air.
"Good carburetion is fuelish hot air". ![]() "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
