Old 08-24-2005, 11:45 PM
andres andres is offline
Unhappy changing bulbs in gauges please help!!!!!!!!!!!!!!!!!!!
how do i change the lightbulbs from the battery gauge the gas gauge and the clock gauge is there a trick to it please help!!!!!!!!!!!!!!!!
Old 08-25-2005, 02:25 AM
Jon Wood Jon Wood is offline
As I recall, the little fittings just pop right out. Wiggling helps. Maybe some other member can verify this...
Old 08-25-2005, 06:58 AM
63pontiacgp's Avatar
63pontiacgp 63pontiacgp is offline
The easiest way is to remove the dashpad and do it from the top. They just pop out, you swap the bulbs and pop them back in. If you've got long arms you can do it without removing the dashpad from below. It is a bit of a pain and time consuming though.
Old 08-25-2005, 08:16 AM
Txbobcat Txbobcat is offline
Disconnect the battery first
Old 08-25-2005, 01:20 PM
mikediaz mikediaz is offline
I assume it is similar procedure (only different position) for the speedometer bulbs?
Old 08-26-2005, 10:46 PM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
Mike on a 65 there are 11(12 with parking brake warning light) on the speedo. All #1895 (6 backlights, 2 turn signals, 1 highbeam, 1 oil, 1 temp, 1 brake if equiped)
Old 08-26-2005, 10:47 PM
LASJayhawk's Avatar
Oh if your gonna pull the pad out read what I posted on the changing a speaker thread.
Old 08-27-2005, 10:39 AM
Deadhead's Avatar
Deadhead Deadhead is offline
Depending on the year - '63 & '64 would be easier to remove dashpad. '66, & I believe '65, you must remove wipers, cowl etc. to get the pad off. '66 has a spring clip on the back of the gauge. This is relatively easily released & removed by pushing a slim flat blade screwdriver into the slot at the bottom of the guage & pushing the gauge upwards towards the dashpad. Then you can put a smaller still flatblade into the clip that holds the bulb into the back of the gauge & pry it out.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
