Old 09-21-2005, 08:58 AM
pggto's Avatar
pggto pggto is offline
Default Pilot Bushing
Whats the easiest way to remove an old pilot bushing from the crank end? Thanks
Old 09-21-2005, 09:10 AM
BILTIT's Avatar
BILTIT BILTIT is offline
Fill the hole with thick axle grease and then shove a shaft (same diameter as the trans. shaft) into the hole and the grease will push the bearing out.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 09-21-2005, 09:14 AM
Bill Hanlon's Avatar
Default Pilot bushing removal
The trick I have heard of (but never tried myself) is:
1. Find a dowel (or use the frontshaft of the transmission) that is a slip fit into the pilot bushing.
2. Fill the bushing center with thick grease.
3. Align the dowel with the hole in the bushing and give it a sharp rap with a hammer driving the grease down into the hole.
The grease is supposed to pop the bushing out.
Be sure to wear eye protection.
Old 09-21-2005, 12:06 PM
fdowdy fdowdy is offline
I've tried the grease pack-'n-pound trick. Works great.
Hmmm.. Now WHERE did this part go???
Old 09-21-2005, 05:13 PM
JoePapa's Avatar
JoePapa JoePapa is offline
a slide hammer works well too...
'69 Firebird 400
http://firstgenfirebird.org/show/closeup.mv?CarID=734
Old 09-21-2005, 09:59 PM
GTOYANKEE1970's Avatar
GTOYANKEE1970 GTOYANKEE1970 is offline
Send a message via AIM to GTOYANKEE1970
I've always used the slide hammer.
John
Old 09-21-2005, 11:06 PM
Formulabruce's Avatar
"GREASE" is the Word......is the word......is the word....... yep, works well
Old 09-22-2005, 07:02 AM
janderson's Avatar
janderson janderson is offline
Grease works well as mentioned, just try and get all the air out when packing the grease or when you strike the dowel or punch (or whatever you are using) the hammer will bounce back. Another method is to tap it and run in a bolt with an impact.
