Old 09-26-2005, 08:33 PM
WINGNUT WINGNUT is offline
Default What size threaded rod for carb mounting studs?
I am changing the Holley on my '72 GTO back to an original QJet. One problem, I can't find mounting studs anywhere. I plan on getting some threaded rod and cutting off what I need. I just need to know what size threads are used for the studs. Does anyone know? Thanks!
______________________________________________
1972 Pontiac GTO 400ci TH-400 (restoration project)
I know what I like, and I like what I know!
Old 09-26-2005, 09:07 PM
Most carb studs are made with 5/16-18 coarse thread on the bottom to thread into the intake, and 5/16-24 fine thread on the top to attach the carb.
Buy some 5/16-18 coarse thread rod to make your own studs.
Old 09-26-2005, 09:53 PM
Thanks!
Old 09-26-2005, 09:58 PM
Goat4three Goat4three is offline
you probably already know this, but if you put a nut on the rod before cutting it and then unscrew the nut after the cut it will help keep your threads in usable shape and prevent cross threading.
"Second place is the first loser"
"That's no oil leak....that's just sweat from all that horsepower."
