Old 10-01-2005, 02:50 PM
ajorda14 ajorda14 is offline
Default Gm Cast Aluminum Pontiac Valve Cover Accessories
Hey guys I just bought those new GM cast aluminum valve covers, for gm parts direct. I paid $140 out the door. I am sick of screwing around with those cheapy chrome covers.
They look like these ones. I've heard good things about them.
Anyways I need to buy new gaskets, I looked online at partsamerica.com,
1) they have standard gaskets and the (ram air/HO) gaskets. What is the difference?
2)Does anybody know what breather hole size is for these covers, I know a few guys have them already. I'll need to pick up up at the local auto store.
3)any special tips to installing these bad boy's leak free?
thanks guys.
Old 10-01-2005, 03:06 PM
KS circutguy's Avatar
Mr. Gasket Ultra's are what I use, X-tra thick and cork to boot.
Super weather strip 3M glue to V-cover side and install.
BTW; nice covers, I want 'Santa' to get me a set this Christmas!lol
Breather looks to be standard size, Moroso makes those and come with the grommets.
Old 10-01-2005, 07:50 PM
Speargun's Avatar
Speargun Speargun is offline
Are they tall enough to clear 1.65 roller rockers?
Old 10-01-2005, 09:32 PM
TransAm525 TransAm525 is offline
No. They require either spacers or grinding the edge of the forward and rear rocker arms for clearance.
Old 10-01-2005, 10:23 PM
Brad B. Hillebrand's Avatar
Brad B. Hillebrand Brad B. Hillebrand is offline
That's a good deal, the parts houses what $195.....what is the web address for gm parts direct sale?
Brad
Old 10-01-2005, 10:36 PM
blizzard9500 blizzard9500 is offline
Cool
Great looking covers, I had a set but did take them back, they will not clear the 1.5 Harland Sharpe rockers even with spacers, contact was made on the top edge of 2 rockers where the top hold down boss on the valve cover dip inwards, you can check this with a finger through groumet hole. Are you going to put a coat of clear on them to help keep them clean? If they ever would become too dirty I always wanted to paint the entire valve cover and then polish out the emblem and the raised Pontiac lettering. I think they would be an awesome looking cover then, Dave.
Old 10-02-2005, 10:55 AM
Nickv's Avatar
Nickv Nickv is offline
All you had to do was grind down the back end of two rockers on each side just a little bit and they will clear just fine. I have these on my 72 with 1.65 roller rockers. No problems at all.
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege"
www.musclecargalore.com
[www.reverbnation.com/nikivee
1967 Pontiac GTO
1967 Pontiac Grand Prix
1972 Pontiac Lemans Sport Convertible
2015 Dodge Challenger Scat Pack 392, 6 speed
2021 Ford Explorer
Old 10-02-2005, 11:01 AM
Yes, that would work, it also would void the warranty on the roller rockers, a chance I was not willing to take over a pair of valve covers, Dave.
Old 10-02-2005, 12:59 PM
If those rockers actually need to be warrantied there's probably other things going on in the motor.
Old 10-02-2005, 01:46 PM
Just like to be using parts the way they are designed to be used, I feel that if a fellow pays $190 or even $140.00 for a pair of valve covers they should fit with out having to modify other internal engine parts, don't you agree?
Old 10-02-2005, 02:06 PM
I agree, but alot of parts have to be modified to be used. Every Edelbrock Intake I've gotten has had to be milled to fit. This is a GM part and they didn't design it for that.
If you want the look of a cast Pontiac valve cover the options are slim. The rockers can handle that that cut off and not affect strength.
Old 10-02-2005, 03:29 PM
cblandin cblandin is offline
Those valve covers clearly state they are for stock valvetrains - aftermarket aluminum rockers aren't stock - they work exactly as advertised. As an FYI, I am using them with stainless 1.65 rockers. I need to pull off one of the covers now that I've finished the engine break-in to verify there hasn't been any contact as even they are very close to the bolt boss.
Old 10-02-2005, 04:18 PM
Speargun's Avatar
Let us know how it turns out. I plan on using Crower stainless 1.65 rockers and would like to use these valve covers.
Old 10-03-2005, 02:00 AM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
1.22" breather hole size ,they will not clear aftermarket full roller rocker arms,you ned to buy alluminum valve cover spacers if you full roller rocker arms .
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 10-03-2005, 02:03 AM
harry k's Avatar
pic
Old 10-03-2005, 10:27 AM
The boss they rub is all the way up so I don't think a spacer will help. They seemed to have room on my Norris SS and Crower SS rockers but only on mock up.
Old 10-03-2005, 10:59 AM
gearbanger's Avatar
gearbanger gearbanger is offline
I have the HS 1.65 rockers, they rub the bolt hole groove on the valve cover. The second rocker from each end need to be rounded off a little to clear. There is plenty of room at the top for the polylocks and rockers. It is the big blocky pushrod ends that rub the valve covers. Wheelspin posted a good post last week on what you need to do.
