Old 10-02-2005, 03:35 PM
Goat4three Goat4three is offline
Default how can i tell what size q-jet i have?
how can i tell what size carb i have on my engine. what size q-jets were/are available. my engine is a '73 model 400 but i can't be certain the carb is the original. where can i go to get this info.
"Second place is the first loser"
"That's no oil leak....that's just sweat from all that horsepower."
Old 10-03-2005, 10:36 AM
Junkyard Dog's Avatar
Give us the numbers off the carb.
Badder than old King Kong
-Jim Croce
Old 10-03-2005, 11:27 AM
P@blo's Avatar
P@blo P@blo is offline
Here is pictures of both 750cfm and a 800cfm...You can see the ring in the primary of the 750 which is not on the 800 version
ID:	28831   Click image for larger version
Old 10-03-2005, 08:55 PM
where are the numbers located?
is that some kind of restrictor ring?
Old 10-04-2005, 12:35 AM
Will Will is offline
There are two basic Q-jet castings, the "750 cfm" and the "800 cfm". The only real difference is in the size of the primary venturi. The primaries were opened up a bit on the 800s to get the extra flow. Without two carbs to compare side-by-side it can be difficult to tell whether you're looking at the smaller or larger venturis, but there is one surefire way - pull the carb, turn it upside down and open the primary butterflies. The 750 has smooth venturi walls all around the booster rings. The 800 has a "bump" in the wall of the venturi adjacent to the booster rings.
The numbers are on the driver's side of the carb on a flat between the primary and secondary side of the carb. Remove the aircleaner and get in there with a flashlight and you'll find them.
Old 10-06-2005, 07:00 PM
the numbers that i found were stamped on two lines, the first line reads:17056259
the second is: 0866 ASC
Old 10-07-2005, 08:13 PM
Pontiac Performance Author
76 olds 350 w/AC--800cfm.
Old 10-08-2005, 04:54 AM
Kenth's Avatar
Kenth Kenth is offline
Very few, if any, of the "M", as in Modified, Q-jet models, 1975 and later is flowing the full 800cfm as the casting allows.
For full 800 cfm flow, the secondary airvalves opening needs to be adjusted to open 1.38" , measured from the rear ridge of the open valve to the back of the choke housing.
Also check that the sec. throttle plates are open 90 degrees +- 5 degrees.
Old 10-08-2005, 10:32 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
If you ever want to look up a Q-jet number, just type it into Google search. Never fails for me.
