This should be easy for somebody but I notice some part places have either parcment interior colors or pearl and some call it white .Is there any difference?
Owner-Atlanta Auto Restoration www.engelsrestoration.com http://www.picturetrail.com/gallery/...me=engelsresto |
I bought a "parchment" interior kit for my 69. It was made by PUI interiors. It definately has a gold pearl in it (and boy, did I ever have fun painting my headrests to match it too). I'm thinking off the top of my head, so if I'm wrong, someone here will correct me, but I believe 68's used the "pearl" interior. Now, I've never personally seen a original 69 parchment interior, but I don't believe it had the gold pearl in it like the 68's. So, my guess is instead of making separate parchment and pearl colored kits, PUI makes the pearl kit to fit both years. Also, it's far from "white". If you put something white next to it, you really see the goldness to it. I like it though, it looks good with my black exterior. Jeff
All 1965 through 1969 Pontiac models used the 'pearl effect' on there vinyl interior color choices. Pontiac called it 'Jewel Toned'. It was actually sprayed on the vinyl and was used on all interior colors-not just parchment.If you look close at original low milage cars you can still see the effect on them. Through the years though most of it has worn off however.I believe Pontiac was the only division to do this on there interiors.
The problem with aftermart interiors(in my opinion) is that when they started reproducing kits the companies assumed Pontiac used the same colors as the almighty Chevy. Chevy only used the 'pearl effect' on Parchment 1968 models and that is what was only available to Pontiac restorers originally. I have seen that PUI and Legendary are finally doing the Parchment correctly but I don't think they spray the other colors. I have purchased the vinyl interior spray Parchment / Clear Pearl and used only the clear pearl on other color interiors with great results. |
So is the pearl effect also on the door panels and seat backs?
Was the pearl spray used on black?
The original '69 GTO I had did have the 'pearl effect' on the door panels, don't remember the seat backs...My '68 Firebird also has parchment/pearl door panels (deluxe interior). The seat backs are parchment, no pearl.
I just purchased replacement door panels for the 'Bird and like supcarbob said, they are parchment w/o the pearl effect. supcarbob, where did you get the pearl paint from? Looks like I'll need it.... Thanks, Mike |
it was used on all interior colors including black. I have purchased through year 1.It is a 2-part parchment/pearl. Just use the pearl top coat over other colors.
the post I read actually discusses mixing a gold with white for the "pearl" effect.
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
