Old 10-18-2005, 09:52 PM
beemergaryw beemergaryw is offline
Default lights surge
63 tempest Lights surge when brights are on the worst or when you step on brakes. Amp gauge always shows a charge. Has not effected battery. Went from points voltage regulator too solid state which helped. HELP THANKS
Old 10-18-2005, 10:01 PM
O ya the alternater is rebuilt and I had it checked out. They told me an alternator makes the power and the voltage regulator borrows from that source to meet the systems needs. You always need a bigger source than you can use. Just like in your home.
Old 10-20-2005, 02:58 PM
engineer engineer is offline
need bigger alternator or smaller pulley for low speed operation.
Old 10-20-2005, 09:10 PM
Its a 6o amp which is bigger than standard
Old 10-20-2005, 09:59 PM
george kujanski's Avatar
A few things: make sure that the regulator is for an "A" body, not a big body.
Make sure the regulator body is grounded well to the firewall and the firewall has a good electrical connection back to the battery negative.
You state the ammeter always shows a charge..is the ammeter standard on your '63? Does it have a idiot light also? If it's always showing a charge, that's correct. Immediately after starting, it should show a higher charge rate, then decrease as the battery gets charged. It should always show a slight charge when the battery is fully charged.
George
Old 10-20-2005, 11:42 PM
Hitman's Avatar
Hitman Hitman is offline
I think I can chime in here. Ground, Ground, Ground. I had a problem and the ground is so important. I had one ground strap that was garbage. The voltage regulator was old and not making good contact. I installed new ground straps from the body to the frame, engine to the frame and the frame to the body and installed a new regulator and made sure those contacts were good and my problems went away. Oh yeah, thanks George and to everyone who helped me on that.
Should you ever find yourself the victim of others peoples bitterness, smallness or insecurities, just remember, things could be worse. You could be them.
Check out my sons blog, www.driftundertheradar.com
Old 10-21-2005, 08:59 PM
Before I switched to the solid state I ran a wire from the negative battery to the regulator. Didnt help. The solid state has been working pretty good till the other night. I have a nos points delco 511 I may have to try which is correct for a 63 tempest. The gauge is the needle type where all the power for the car runs through first before it goes anywhere else. Kinda scarey!
Old 10-30-2005, 02:09 PM
Default PROBLEM SOLVED
Ran a wire from bat. to votage regulator. Surge went away. There was a poor connection at ignition at the wire that goes to the regulator. Poor connection was telling voltage regulator we need power when we didn't. Two burnt out t 3s, one pertronics ignition and two new voltage regulators.
