Old 11-09-2005, 09:11 PM
Vortex Vortex is offline
Default lowering the seat
While Im here, another quick question. After years (10) I finally had the interior redone on my car. The problem is now with the new springs/foam ect... the seats seem way higher than before and my head almost touches the headliner. Im a big guy but I didnt have that problem before. I have seen the two racks the seats bolt onto the floorboard anbd they are the originals. Is there any cure, such as modified seat mounting brackets that are lower? It is a real pain getting in and out as well as now my damn thighs have to squeeze under the stering wheel. Any advise appreciated.
Old 11-10-2005, 12:19 AM
rgto273 rgto273 is offline
I have a similar problem being 6'4. I was told to cut the seat rails. Pull the seat all the way up and you'll notice the rail will end, and then turn and drop down about an inch before turning into the bracket which you bolt together. Cut that drop part off and weld the rail back together and then cut the front the same amount. I never tired it because I wasn't sure about the plastic seat tirm hitting the floor. Its an idea you might look at.
Old 11-10-2005, 12:58 AM
Tripower455's Avatar
Just drive it and it will come down. Mine was the same way when the interior was brand new. 850 miles later, it is perfect.
Old 11-10-2005, 09:58 AM
bobbyj1's Avatar
bobbyj1 bobbyj1 is offline
I am 6'4" also, when I recovered my seats I purposely used the old foam to avoid what has happened to you. I am sure they will settle a little over time
67 GTO Hardtop
Old 11-10-2005, 10:25 AM
winbub's Avatar
winbub winbub is offline
Default Another tall guy.
I'm 6'5" and still have the original seat covers and stuffing in my seats. I too am concerned about when I re-do the interior...I don't want to be like Dino in Fred Flintstone's cruiser.
1966 GTO Coupe(#1845), AT, PS, PB, Nightwatch Blue
389 built by Gaydosh Performance - .040 over, 670 heads, 4bbl 750 Holley Double Pumper, Edelbrock Performer intake, Howards CAM and lifters, Scorpion roller rockers, TRW rods and pistons, Doug's headers, new TH350 with shift kit & 2000 stall, 8.2" rear with Auburn carrier & 3.55 posi Richmond gears
http://www.cardomain.com/ride/2240898/1966-pontiac-gto/
Old 11-10-2005, 12:16 PM
meanolgoat meanolgoat is offline
Do you have the seats mounted on top of the carpet and padding? You can gain a little room by cutting a flap in the carpet and padding and mounting the rails directly to the floor.
Old 11-10-2005, 01:19 PM
Rugratman's Avatar
Rugratman Rugratman is offline
Wow, alot of tall guy's here....
6'2" here. They will settle down, I fit fine, but the helmet will rub a little.
Look at this pic and how big my head looks in the car.
Name:	P1010011 (Small).jpg
........I'm just learning as I go.......
Old 11-10-2005, 09:14 PM
Thanks for all the replies. I guess Ill just drive it a while and see if it goes down by itself. With my fat ass in the drivers seat, it should compress some I guess. If not, those mounting brackets will have to be cut.
Old 11-16-2005, 11:09 AM
gtoguy389 gtoguy389 is offline
rugrat you do have a big head. Very nice '67 also.
I am 6'4" and had the same problem with my '69 after new interior was done. It has settled after driving it for a summer but my head still rubs the headliner a bit. Had to develop a comforatble crouch to fit in the car. I guess my head is big too.
I am doing my '66 post right now so I will look at lowering the seat by modifying the tracks before we put in the interior. Also I have seen the brackets used on Firebirds to move the seat back 2" for more leg room. Will these work on A-bodies also? The lack of leg room especially in 64-67 cars makes it hard for anyone over 6'2" to get in and out.
Life is tough. It's tougher when your stupid. - John Wayne
