Old 02-26-2006, 12:26 AM
transam72n73 transam72n73 is offline
Question Clarification for 72' T/A Distributor Part Numbers
I am a bit confused over what is the correct distributor part number for my 1972 TA. I have an automatic transmission. I was of the understanding that the 72 TA came with an optional unitized distributor (P/N 1112133). Is this a true fact? If so, what is the 'standard' distributor part number without this option? My build sheet does not call out the 634 sales code.
Please help clarify since it is not obvious in the 72 service manual and I can't seem to find literature that clarifies this information.
Thanks in advance.
Old 02-26-2006, 01:27 AM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
In 1972 the Trans Am is the only 455 HO equipped vehicle to come with a points distributor as standard. P/N used is 1112126.
The unitized distributor #1112133 was a mandatory option on 455 HO equipped A-body and Firebird Formula.
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 02-26-2006, 10:20 AM
Formulabruce's Avatar
the 72 service manual pre-dates lots of info I noticed.
" Long may we DRIVE !"
Old 02-26-2006, 07:50 PM
AndyLong AndyLong is offline
As far as I know all 72 455-HO had unitized ign only, good luck locating these parts.
Andy
ID:	43900   Click image for larger version
Old 02-26-2006, 07:52 PM
Formulabruce,
That's why the Pontiac Craftsman Service News is handy.
They usually have the corrections and other tid-bits.
Old 02-26-2006, 09:19 PM
njsteve's Avatar
njsteve njsteve is offline
Andy
The 1972 455 HO Formulas had the unitized ignition as a mandatory option. The Trans Ams came standard with the #26 point dist and the unitized model was optional. My car has the WD coded block with the point distributor. The WM came with the unitized. Similar with the YB=points and YE=unitized. The PHS sheet will tell you if your car had it, if you dont have the buildsheet.
Old 02-26-2006, 11:18 PM
I checked the block again to be sure. The block is a YE code and matching number. I bought the car from the original owner, have the paperwork right down to the purchase docs he signed when he took delivery of it in Feb 1972, Protecto Plate and PHS docs. Car was built 2nd week Dec 1971. My PHS docs don't mention the unitized distributor option but the car is a YE code block. Has anyone heard of a situation where it was not called out on the build sheet but in fact came with the unitized distributor. I suppose with GM, anything is possible.
Old 02-27-2006, 03:16 PM
toomanybirds toomanybirds is offline
The 72 455 HO engine codes for the unitized distributor were YB for the automatic and WM manual transmission. The points distributor codes were YE and WD.
Your TA is correct with a YE block and a points distributor. The points distributor number is 1112126.
njsteve has the automatic codes reversed in his post.
Old 02-27-2006, 03:42 PM
njsteve's Avatar
Sorry about that, my typing dislexia got in the way again!
Old 02-27-2006, 10:50 PM
Sorry if I missled you, but my info was misleading, This forum and its members are great. There may be a set of nos date coded wires at my brothers house, I can ask him the details for you.
Andy
Old 02-27-2006, 11:36 PM
No problem Andy. Thanks all. That clears it up, now on to get find a 1112126. Andy, let me know on the wires, I'm more fixed on getting the right distributor at this point. If any one comes across this item, please keep me in mind.
Mike
Old 02-28-2006, 08:22 AM
Wick's Avatar
Wick Wick is offline
I have one that is very nice, still has the purple paint stripe on it from the factory. I pulled it from a '72 back in about '82 when the car had around 50K miles on it.
_____________________________
She woke up sunny side down and I was still thinking I was too proud to flip her over
Old 02-28-2006, 09:19 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Exclamation
SOLD!
Gimme a ring at work, please.
Won't be any packing or shipping involved either.
(713) 664-5118 work or (713) 825-7721 cell.
TIA.
Regards,
"455HO" Lloyd
Old 02-28-2006, 10:17 AM
njsteve's Avatar
Does anyone else have a spare 1112126 dist? I still need one for my 72. Thanks, Steve.
Old 02-28-2006, 10:34 AM
Lloyd-TX's Avatar
Steve:
Gimme a call or e-mail me @ work.
(713) 664-5118
Regards,
"455HO" Lloyd
Old 02-28-2006, 10:46 AM
Those wires are for sale, now you have it all, I wish it was that easy for everything "A"
Andy
Old 02-28-2006, 11:01 AM
Wick's Avatar
Distributor is still available.
Old 02-28-2006, 02:58 PM
njsteve's Avatar
I need the distributor. I pm'd you.
Old 03-03-2006, 09:42 PM
Wick's Avatar
Steve, I took the distributor by Lloyd's shop today and it NOT a restamp.
Old 03-03-2006, 11:25 PM
njsteve's Avatar
Thanks for the info Chris. It definitely is a one of a kind piece with the post-UAW strike date code.
