Old 04-17-2006, 11:14 AM
Hawk397 Hawk397 is offline
Send a message via AIM to Hawk397
Default Anyone Run (Try to Run) 8" Rims with a 5" Back Space?
I'm currently trying to fit 8" with a 4" BS (26" tall tire) on my 71 bird. Looks like it sticks out about 1/2 to 3/4" to much and may rub the lip.
I found a really nice rim that I like but it's 5" BS - has anyone verified that this will run and clearance ok?
Thanks!
Mark
71 Firebird Custom - Fuel Injected & Over-drived!
Old 04-17-2006, 08:41 PM
71firebird400's Avatar
71firebird400 71firebird400 is offline
I run a 15x8 on my '71 Firebird with 4.5" backspacing. I think that 5" would be fine. My tires stick out a little from the rim (275/60-15) and they come just up to the fender without rubbing; so I think extra half inch of backspacing would be fine.
Old 04-17-2006, 11:02 PM
Dirty70Bird Dirty70Bird is offline
I run a 15x 8 x 4.75 B/S rim. Its a special order torque thrust, CL205 series. The tires are 275x60s. No rubbing. IF I remember correctly, I got about 1/2 between the tire and the leaf spring, so there is room to go.
http://www.hbci.com/~chriss/PhaseSix/RRear.JPG
http://www.hbci.com/~chriss/PhaseSix/Rear.JPG
Old 04-18-2006, 06:54 AM
cnc's Avatar
cnc cnc is offline
Talking
any more pics of your car and engine i'm building a 70 also nice pic of wheels too if possible i like the torque thrusts
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 04-18-2006, 11:17 AM
Thanks for all the info guys!
Mark
Old 04-18-2006, 12:38 PM
I wouldn't cut it any closer than that. Tire sidewalls can deflect quite a bit under hard cornering.
Old 04-26-2006, 09:08 PM
Sorrry for the delay. Here is the main page: http://www.hbci.com/~chriss/
Enjoy!
Old 05-26-2006, 12:55 PM
Pzr's Avatar
Pzr Pzr is offline
Great work!
Still surfing your homepage, impressive and inspiring!
White pearl firebird -71
