Closed Thread
Old 07-12-2006, 10:45 PM
TUNNEL PORT's Avatar
TUNNEL PORT TUNNEL PORT is offline
Default 64' - 67' A-body pic
Here's a pic of the 64' - 67' A-body headers. I took these weeks ago & just got a hold them from my friends camera. These are robscar's headers before they went to the coater
Old 07-12-2006, 10:52 PM
Default pic
Here's Djife's. He had the Ball Sockets installed on his. Buy the way I don't charge extra to install the ball sockets like others may. If there sent to me I'll do them its no biggy. Oh don't mind the crack in the concrete. After all I am in Ca.
Old 07-12-2006, 10:55 PM
Goatless, your headers look just like robscar's. All three are at the coater.
Old 07-12-2006, 11:14 PM
goatless's Avatar
goatless goatless is offline
Well then let's say that's a pic of my headers and robscars look just like mine.
1966 GTO
  #145
Old 07-12-2006, 11:17 PM
Default test
Here's a dyno test that was sent to me today, keep in mind this isn't in any way a streetable set up. Also there was no tuning done on the Tri-y dyno pull so its a pretty equal start in comparision without optimising the tuning.
I have one guy that has a 68' A-body that he races in the stock class. As you probably already know hoe strict that class is. Since almost everything needs to be stock & year correct parts. If any mods are allowed its limited to very few parts at all. So weight, lift, engine size, compression ect are all checked.
The only real things they can change is cam duration but not lift. The exhaust can be anything they want. Gear ratios & stall speeds.
Anyway he spent the day getting a base line dyno test on his motor with Hooker 1 3/4" headers. Then when he got a set of the D-port Tri-Y's the other day he did a dyno test with them.
His engine was tuned & set up for the Hookers. He's ran the car for a long while with the Hookers. He did NO changes other than the headers between dyno pulls. He didn't have time for No timing, jetting tuning on the Tri-Y's. So I don't know if or what tuning like timing or jetting the Tri-Y's would work best with on that motor.
Its the only test so far I have with a 108 LSA. It does show what I had mentioned before on the other tests. That the tighter the lsa gets the more equal the #'s seem to get between the two headers. The test I posted before using 110 - 112 lsa cams showed more or same hp between the two headers tested & 5 - 10 lbs more trq for the Tri-Y's in those tests. Also the wider lsa cams lasted over a much longer rpm range the 4-tubes did.
He did not have the rpm lower than 4500 so I can see if its still a wider rpm rang of power. Since this motor leaves the line above 4500rpms at the track. He may do more tests later on another motor. After a few weeks.
Engine info:
’68 Pontiac 400+.030” – factory 350 hp rating (std – non ram air) - blueprinted
16 heads – no porting – 3 angle valve job only
stock lift cam - .421” int/.425” exhaust – 250-260 degree duration (a secret)
108 lobe sep
cast iron intake – pn 9794234
Q-jet carb
approx. 12:1 compression
Header Comparison
Best Pulls
Jul-06 Jul-06
Pull # 9 12
TQ
.....Hooker Tri-Y
4500 502.3 501.6 -0.7
4600 501.1 491.1 -10.0
4700 489.9 487.0 -2.9
4800 493.7 491.1 -2.6
4900 488.0 485.3 -2.7
5000 488.3 487.6 -0.7
5100 482.2 482.4 0.2
5200 476.5 481.5 5.0
5300 473.1 473.5 0.4
5400 469.4 469.0 -0.4
5500 460.2 457.7 -2.5
5600 459.6 452.9 -6.7
5700 454.5 444.6 -9.9
5800 443.1 440.7 -2.4
5900 436.4 439.1 2.7
6000 433.4 426.8 -6.6
6100 424.1 422.1 -2.0
6200 407.9 408.0 0.1
6300 397.8 395.8 -2.0
6400 387.7 387.4 -0.3
6500 375.3 378.4 3.1
HP
4500 430.4 429.8 -0.6
4600 438.9 430.1 -8.8
4700 438.4 435.8 -2.6
4800 451.2 448.8 -2.4
4900 455.3 452.8 -2.5
5000 464.9 464.2 -0.7
5100 468.2 468.4 0.2
5200 471.8 476.7 4.9
5300 477.4 477.8 0.4
5400 482.6 482.2 -0.4
5500 481.9 479.3 -2.6
5600 490.1 482.9 -7.2
5700 493.3 482.5 -10.8
5800 489.3 486.7 -2.6
5900 490.2 493.3 3.1
6000 495.1 487.6 -7.5
6100 492.6 490.3 -2.3
6200 481.5 481.6 0.1
6300 477.2 474.8 -2.4
6400 472.4 472.1 -0.3
6500 464.5 468.3 3.8
avg 479.0 477.0 -2.0 4800-6200 rpm
There Mr-P I named this one
Old 07-12-2006, 11:21 PM
OK Goatless, there yours. Sorry rob for not posting a pic of yours
Old 07-12-2006, 11:48 PM
Formula8's Avatar
Formula8 Formula8 is offline
Hey Ron, good to see you are making progress!! Somewhere down the line, I will need a set of round ports. It's a ways off though.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
  #148
Old 07-13-2006, 12:01 AM
johnsma22's Avatar
johnsma22 johnsma22 is offline
Talking They have arrived!
Well folks, it has been a long time in coming, but my Tri-y's have arrived! They look great, and feel more heavy duty and substantial than what I expected. The coating is very well done also. After actually having them in my sweaty little hands, I can see how much planning, measurement and tooling is required to get all these bends and angles just right to actually get them to fit into a car properly.
The quality of the fabrication is better than I could have hoped for. I can't wait to get them installed on my car. It probably won't happen until next spring. I'll be building my E-headed 400 into a 461 over the winter, adding a TKO-600, and a Moser 12 bolt along with a 3" exhaust. I just want to actually drive the thing for a whole season before I tear it apart again. I wish Ron all the best in this continued endeavor.
Here are the photos I promised.
John
ID:	58738   Click image for larger version
ID:	58739   Click image for larger version
ID:	58740   Click image for larger version
ID:	58741   Click image for larger version
John
"There are no stupid questions, but there are a LOT of inquisitive idiots!"
  #149
Old 07-13-2006, 12:05 AM
johnsma22's Avatar
...and a few more
ID:	58746   Click image for larger version
ID:	58747   Click image for larger version
ID:	58748   Click image for larger version
John
  #150
Old 07-13-2006, 07:54 AM
Larry Navarro's Avatar
Wow!!
Even attention to detail in packaging.
Fine looking product Ron.....but then I already knew that.
  #151
Old 07-13-2006, 08:26 AM
gearbanger's Avatar
gearbanger gearbanger is offline
Those are awesome.
  #152
Old 07-13-2006, 01:12 PM
Thanks Larry for the camera. Of course the raw un-coated sets don't get as much bubble wrap.
So Remember:
Its also fun for the whole family & will keep the kids busy popping bubble wrap for minutes. So keep that in mind when ordering.
Coated set = 10min of alone time (leaves a satisfied kid likely to take a nap)
un-coated = 2 - 5 min of alone time (& most likely leaving kids wanting more)
See Chart:
So as you can see its all about the kids!
(Results may very. May not work in all areas. Multiple kids may have disastrous effects. If annoyance or swelling of the brain continues contact a doctor immediately to get a drug called "Ridilen" & have kid take as prescribed.)
Just think what you can do with that much needed time:
Sit there & cuddle your new headers
Go to the garage to show your car & tell it all about them
Make phone calls to all your buddy's about the package without having to yell over the kids
Alone time with the wife & possibly end up with more kids (this is my personal favorite) Which would require future packages of coated headers.
Old 07-13-2006, 01:28 PM
Just for comparison here's the earlier Dyno test from KRE I had posted awhile back using a 112 lsa against Hedman Hustlers. This is a typical street build
Tri-y Peek # 's Hp 491.4 / Trq 543.7
Hedmans Pk #'s Hp 491.0 / Trq 538.0
461cid
KRE Aluminum D-port heads (stock)
Crower 60919
112 Lob sep
1.65 rockers
RPM intake
850 Demon
RPM's Trq Trq
. 1 3/4" 1 3/4"
. Hedmans Tri-ys
3700 522.2 527.9
3800 526.9 537.5
3900 529.9 540.6
4000 533.6 543.2
4100 532.1 542.2
4200 531.2 (543.7)
4300 526.2 535.7
4400 534.8 539.8
4500 (538.0) 535.9
4600 530.9 531.9
4700 522.2 526.9
4800 510.7 516.9
4900 494.8 502.8
5000 490.8 500.8
5100 490.4 496.9
5200 489.4 489.0
5300 481.5 483.0
5400 477.6 472.2
5500 468.1 469.2
5600 454.5 459.7
RPM's Hp Hp
. 1 3/4" 1 3/4"
. Hedmans Tri-ys
3700 367.9 371.9
3800 381.2 388.9
3900 393.5 401.4
4000 406.4 413.7
4100 415.4 423.3
4200 424.8 434.8
4300 430.8 438.6
4400 448.1 452.2
4500 460.9 459.1
4600 465.0 465.9
4700 467.3 471.5
4800 466.7 472.4
4900 461.6 469.1
5000 467.3 476.8
5100 476.2 482.5
5200 484.6 484.1
5300 485.9 487.4
5400 (491.0) 486.6
5500 490.2 (491.4)
5600 484.6 490.2
Old 07-13-2006, 02:32 PM
Ron H's Avatar
Ron H Ron H is offline
Is there any First Gen firebird headers in the works yet? Possibly a 2" round port for high port heads?
68 Firebird
Are you running with the wind or breaking it?
  #155
Old 07-13-2006, 08:21 PM
Ron H,
I have a pattern that I worked on last year when I had a friends car for a short time. There's one area on the pattern that needs to be changed. So when I get a chance to get the car back I can finalize them. I have a few to do before that can happen.
Formula8,
Great, is this a new car or was it already in the works?
Old 07-13-2006, 10:57 PM
dreambird72's Avatar
dreambird72 dreambird72 is offline
Johnsma22 - Love the "intimate" portraits you took, the burgundy leather really highlights the headers masculine side even though having "smaller tubes" :0
Ron - When I get mine should it be a Family occasion or an intimate moment, just The T/A, headers, & me ?
Why dont we all go on "The Man Show" and tell our story
the wife will think Ive totally lost it !!
Contact Me on NEW ID = Silverbird
  #157
Old 07-13-2006, 11:11 PM
Formula8's Avatar
Ron, I'm just looking forward to a switch to aluminum heads. Probably a couple of years down the road. I want to see how the KRE heads develop.
  #158
Old 07-14-2006, 12:07 AM
dreambird,
Once you guy get them, hey you can spent your time with them any way you want intimate or just a casual acquaintance.
I belive the 1 3/4" tubes are average size, right?
All I know is I have spent many nights at my shop just polishing pipe (metal pipe! What were you thinking ) for the headers. Because the wiper die on my bender for the 1 3/4" tubing is badly worn. From back when I got the wrong tubing delivered in June of last year. So it scratches each bend petty bad. So I'll spend just as much time as it took to make each piece from start to ready to weld just polishing the scratches out. Just so it wont show through the pretty coating.
Once I get caught up & have $600 to spend I'll get a new wiper die & I'll instantly be twice as fast from no more polishing.
Formula8,
I think Kre will have many improvement on there heads over the next year. After all they haven't been out long.
Old 07-14-2006, 09:24 AM
gearbanger's Avatar
Are you talking about KRE D's or highports? The KRE D's are awesome. My 461 engine is making a tone of power (550-600 hp)and it is more streatable that ever before. I just drove it to Gatlinburg TN for the weekend (about a 3 hr one way trip) and I wouldn't hesitate to do it again today. I just need to get these 1-5/8" Hookers off of it to really make it happy, HINT HINT.
  #160
Old 07-14-2006, 05:07 PM
I have robsar header's shipping on Mon & Djife's headers shipping on Tue. Different shippers is the reason for separate days.
I have Goatless's set going on next Fri. I hope to have 1 to 2 more
D-ports leaving on that Fri with his also.
By the way thanks to Rob (robscar) a few sets are going to be sent out alot sooner than they were going to be. He's a true help to me & the others that will now get there headers without the delay that was caused by the pay-pal issue. I have yet to see how many more it will effect.
In case a bus hits me tomarrow & I don't get a chance.
I better give thanks to the guys that helped out through the hard times
In No particular order all had a hand in some way in the production & keep it going:
Larry
Brian '74
johnsma
robscar
Wade congdon
Jeff @ kre
Formula8
Yellowcar
TURBOWNER
& all the support of the patient customers both 1st & 2nd runs.
Better put the wife in there too for other suport
Closed Thread
