Old 07-19-2006, 10:48 PM
rschwartz rschwartz is offline
Cool 93 Grand Am cold a/c but not strong blow
Hello,
I have a 93 Grand Am that has cold a/c but I can not get any volume of air out of the vents I did find the flap was broken and replaced it and I have watched it and it seems to close correctly and the blower motor is also new could there be something plugging the air chamber somewhere and how would I be able to check that?
Randy
Old 07-19-2006, 11:15 PM
LPete LPete is offline
I've seen GM evaporators get plugged up with oily crud so badly that air can't go through. You may be able to see the evaporator if you take the blower motor out. I can check at work and see if you can't figure it out.
FYI, all the heater air goes through the evaporator first, so the airflow will be restricted even if the AC is off.
Old 07-20-2006, 12:46 PM
That makes sense even when the heater is on full there is not much airflow.
Randy
Old 07-22-2006, 06:02 PM
Thanks for the advice it was the evap core was coated with junk cleaned it up and it blows cold air now ! Thanks again!!
Old 07-22-2006, 06:10 PM
Glad that took care of it!
