Closed Thread
Old 07-14-2006, 08:18 PM
TUNNEL PORT's Avatar
TUNNEL PORT TUNNEL PORT is offline
Your quotes not working. its clearly missing something
Ya, know if I didn't have my name written on a piece of paper in my wallet, Id forget that too! 1/2 the time I forget where I put it until look to see what that lump is my rear pocket.
I emailed you a week or so ago. You never emailed back.
Old 07-15-2006, 12:46 AM
johnsma22's Avatar
johnsma22 johnsma22 is offline
Just thought that some of you might be interested in these photos. Check out the access to all of the header bolts. Especially the center ports! Should be a snap to get a wrench on all of them.
John
ID:	59012   Click image for larger version
ID:	59013   Click image for larger version
ID:	59014   Click image for larger version
John
"There are no stupid questions, but there are a LOT of inquisitive idiots!"
  #163
Old 07-16-2006, 06:12 PM
I need a set of motor mounts that go on the subframe not the ones on the motor. For a 70' - 71' bird. I can't use 72' - 74' because they are different distances between the bolts.
If anyone has a set or knows someone that does it would be great. Because I have a subframe here that I was going to use just for mock ups & it didn't have mounts on it when I got it. I tried the ones from my 73' & they were slightly off on some of the bolt holes & way off on some.
My shop is barely bigger than a 2 car garage & have a few uses for it other than just headers. So its going to be a permanent fixture/tool in my shop. So rather than having a whole car & not getting another in at the same time. I got this from craigslist for free. So I couldn't complain about it having no mounts. I have had this for months & haven't found any for it yet.
Old 07-19-2006, 03:29 AM
Here's the two sets (64' - 67' A-body) I last posted coated
Old 07-19-2006, 08:46 AM
gearbanger's Avatar
gearbanger gearbanger is offline
Hey Ron,
Those look really nice. If you can do it, I think I would rather have those 3 bolt flanges than the slip fit collectors. Mine are 64-67 A-body 4-speed coated D-ports, so if you could, make the collectors like that second picture above.
  #166
Old 07-26-2006, 10:08 PM
robscar's Avatar
robscar robscar is offline
There is much happiness in the household today! Yes, they have arrived! They look fabulous!
I am going to try to leave work early tomorrow and get started on the installation. I will try to post some pic's of my progress. I left the fenders and inner fenders off on purpose to make it easier for me to install and take pic's of.
ID:	60109   Click image for larger version
  #167
Old 07-27-2006, 01:55 AM
djife1 djife1 is offline
Smile
Yup it's Christmas in July in NY today Got my hedders from Ron (BTW they look great)and got my American Racing Hopsters 20x10 & 18x8. Now to get it all installed. Thanks Ron
ARM
  #168
Old 07-27-2006, 08:13 AM
gearbanger's Avatar
Dude, you better post some pictures of that when it's done. I love GTO's with big wheels!
  #169
Old 07-29-2006, 05:53 AM
Well I installed the hedders today (Friday). Install time was an hour and a half and very easy. I have never installed a set of hedders so easily thanks again Ron fit was perfect.
ARM
  #170
Old 07-29-2006, 12:27 PM
robscar's Avatar
I beat you all! I put mine on Thur, then I had to go do some other things Thur and Fri and could not post until now.
Being that I had left the fenders off my install was the easiest that I have ever done. Although I will say that all the others that I have done were mopars.
If you follow Ron's instructions you will not have any problems.
I started with the left side since that one came up off the frame first when I lifted the engine. I removed the starter and the darn thing practically jumped onto the car. total time-15 min. Half of that was cutting the bubble wrap off of the header itself. I had left it on for protection. At this time I had only put 4 bolts in to be sure of the fit. I later spent another 5 min putting the other 4 bolts in and tightening them all up. Another 5 min to put the starter back on and that one was done.
The right side was a bit more difficult. This one I had previously removed the bubble wrap to look at the header so I just wrapped it back up and got to it. If you follow the directions it will go very easy. Ron said the engine should be lifted between 1/2 and 1 inch and he was right. He also said the dipstick would present a little problem and he was right again. 5 min to remove the oil filter housing, 15 min to get the header up and into place, 5 more min to put in the bolts and tighten them up and that one was on. I left the oil filter housing off to take some pic's.
I can only hope the rest of the exhaust will be half as easy.
Here are a few pic's to look at. I have many more and can take some of a particular item if anyones needs one.
Name:	front to rear view #2.JPG
ID:	60316   Click image for larger version
Name:	rs looking at trans mod.JPG
ID:	60317   Click image for larger version
Name:	left side @ starter.JPG
ID:	60318   Click image for larger version
Name:	ls ground clearance.JPG
ID:	60319   Click image for larger version
Name:	front to rear view #3.JPG
  #171
Old 07-29-2006, 12:33 PM
robscar's Avatar
I forgot one. here's the old girl making her pictorial debut. Lights, camera, action!
ID:	60321   Click image for larger version
Name:	leftside mount #2.JPG
ID:	60322   Click image for larger version
Name:	leftside front bolts.JPG
ID:	60323   Click image for larger version
Name:	left side rear bolts.JPG
ID:	60324   Click image for larger version
Name:	leftside frame clearance.JPG
  #172
Old 08-02-2006, 07:13 PM
robscar's Avatar
Talking
the old girl runs and she sings sweet music to my ears. After some electrical brainstorming I got her running a little while ago. Tri-y's, 2 1/2" pypes X system with race pro 14" mufflers. The wife could hear her from a bit of a distance and being in the house. If I can fix the electrical glitch so she will start when i tell (ask) her to it won't be long till I'm on the road again!
  #173
Old 08-18-2006, 08:28 AM
gearbanger's Avatar
Originally Posted by gearbanger
Hey Ron,
Well, another month has gone by since I asked Ron if he would use the 3" collectors on my headers, but still no reply or even an acknowledgment of my existence. Does anyone have any idea if Ron saw my post or got my e-mail, phone call or PM? This is so unreal.
  #174
Old 09-12-2006, 11:31 AM
Ducks Goat's Avatar
Ducks Goat Ducks Goat is offline
Any new information on when the rest of us will get our headers?
1999 WS6 Formula, 1 of 175
1967 GTO Linden Green 4 spd, A/C, survivor
1967 Lemans convt
1967 Firebird 400 bench seat, deluxe interior, auto
1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, [email protected] (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne.
1961 Catalina 2 door htp
1960 Ventura 4 door htp wife's car
1960 B'ville 2 door htp
1960 Catalina Wagon wife's car too
  #175
Old 09-12-2006, 12:56 PM
Glenn Glenn is offline
On Vacation
Sounds like Tri-Y's and Rodney Red are operated by the same person.
  #176
Old 09-12-2006, 05:05 PM
oldblueponcho's Avatar
oldblueponcho oldblueponcho is offline
I went ahead and ordered a set of round ports for my bird from Ron a couple of weeks ago. He was very easy to work with and answered my emails in good time.
Some Fear, Because if you've never been afraid- just a little. You're obviously not going as fast as you could be.
  #177
Old 09-12-2006, 05:22 PM
robscar's Avatar
I am sure Ron is working to get all the orders out as fast as he can. I know I really like mine. The engine compartment is much quieter than I thought it would be. But out back the Pypes exh system is another story. I have been asked what kind they were a couple times already. The fit and ground clearance are great!
Be patient and you will be rewarded, and then you too will be pleased with the product.
  #178
Old 09-12-2006, 06:10 PM
That's what I was thinking Rob. The guys who have the headers already are totally happy with them, Which was a big seller for me. Also I know my car isn't going to be up and running again till next year anyways, so it's not a real big issue to wait a while.
Also, when I was setting up the purchase with Ron, he told me that he's past a lot of the hang-ups he was having and the waits aren't nearly as long as the had been. I'll stand by him.
  #179
Old 09-12-2006, 08:33 PM
gearbanger's Avatar
oldblue, since Ron does respond to your e-mails, could you ask him to put those three bolt flanges on my headers. It is coming up on two months since I asked him and still no responce. Hopefully you won't find that once you have paid him, the customer attention goes away like it has for so many others. Good luck Bro....
  #180
Old 09-13-2006, 09:49 PM
robscar's Avatar
I will also add that since I installed them I retightened the bolts once right after the engines first start which was only for a couple min. Since then I have not had to touch them again. I now have a couple hundred miles on her. That, so far, is pretty maintenance free.
Closed Thread
