Old 10-16-2006, 01:42 PM
fyrebird68's Avatar
fyrebird68 fyrebird68 is offline
Question Shop tip needed ...
How do you guys hold the engine stationary (400/TH400) when breaking loose the harmonic balancer bolt?
I tried a screwdriver wdged in the torque converter, but its a little too springy. Can't get a clamp on the flex plate - no place with sufficient clearance.
Tell me your secret!
Thanks,
Bob Trimpe
Old 10-16-2006, 02:33 PM
71lemanssprt's Avatar
71lemanssprt 71lemanssprt is offline
do you have the cylinder heads still on if so fill cylinder bores with oil and pull the pushrods leaving the spark pluggs in . this wil create hydraulic lock. if none of the above are possible try bar thru flywheel hole the turn engine till bar locks against block. good luck
Old 10-16-2006, 03:26 PM
Old Goat 67's Avatar
A lenght of rope in one of the cylinders will work also. Just be sure to leave the end sticking out.
Charles
Old 10-16-2006, 03:41 PM
meanolgoat meanolgoat is offline
I've placed a screwdriver, or prybar, thru one of the holes in the flywheel, and then wedged it against the Starter mounting pad on the block. (after removing the starter of course)
Old 10-16-2006, 04:42 PM
sstripes96's Avatar
sstripes96 sstripes96 is offline
1/2 inch impact or a fly wheel tool.
Bud
Lawrenceville GA
73 Firebird
96 Impala SS
Old 10-16-2006, 05:10 PM
engineer engineer is offline
cheater bar wedged against frame and bump starter over with coil wire disconnected or the Indian rope trick per old goat 67.
Old 10-16-2006, 06:52 PM
carcollector's Avatar
carcollector carcollector is offline
Just use a long socket extension and you'll have no problem finding a place to brace it thru your flexplate. Give yourself plenty of room under the car.
Reality is the ultimate payback
Old 10-17-2006, 08:33 AM
fyrebird68's Avatar
The "Indian rope trick" worked for me.
It's amazing how much clothesline fits inside a 400ci cylinder - over 20 feet!
Thanks for all the tips.
Bob Trimpe
