Old 10-17-2006, 12:22 AM
formulabird428's Avatar
formulabird428 formulabird428 is offline
Default quickfuel/proform carbs
curious about both them:
quality?
how do they match up vs. Holley?
how long have they been around?
durability?
adjustibility?
what pressure are they rated at?
comments?
btw, i'm looking at 950-1050cfm, professional/race series...probably annular boosters as well...
Old 10-17-2006, 05:35 AM
DINO1's Avatar
DINO1 DINO1 is offline
Holley has some serious competition with these guys. They definatley build a better carb for less money. All the Pro series carbs are pre run, have billet hardware, sight glasses on both sides of the fuel bowls, and the fuel bowl screws go in deeper to the main body. I have the 1050 anular booster pro series and am very happy with it. If your in the market to buy a Holley, get the Quick Fuel instead and save yourself a couple hundred bucks.
Old 10-17-2006, 08:24 AM
PONTIAC DUDE's Avatar
Thumbs up
Sell qiute a few and run great. I like em.
Even had Mike Davis brother-in-law Ken take a well know carb builder prepped carb they recommended for his combo off and install a Quick fuel and pick up a few tens. Here ya go.
http://www.angelfire.com/fl4/pontiac...ilbrenner.html
Another combo and goes thru quite a beating in the ole Mud holes without a falter.
http://www.angelfire.com/fl4/pontiac...alhosfeld.html
BTW: These are out of the box carbs with jet changes only.
Old 10-17-2006, 04:03 PM
SCOTT ESTERLE's Avatar
SCOTT ESTERLE SCOTT ESTERLE is offline
Quick Fuel has a nice carb. There run by a couple of ex Holley employee's. Check out there address there right across the street from Holley. I tried one of there 1050 4150 style carbs against my Barry Grant modified 750 which flows around 900. I lost 2mph. The car ran fine but the ET slip does not lie. I would have thought if it was too big i would have bogged the engine down or would have been running really rich & none of this was the case. Now i don't have an egt so i can't compare those #'s. But there carbs look real nice & the one i tried ran good just slower than my other carb.
Old 10-17-2006, 05:27 PM
at what pressure are they rated at?
does the whole 1050cfm actually = 900cfm thing apply...or, is 1050cfm ACTUALLY 1050cfm?
***also, would it be better to go for a 950 downleg or 1050 annular?
Old 10-17-2006, 09:36 PM
meanken meanken is offline
BTW: These are out of the box carbs with jet changes only.[/QUOTE]
For what it's worth, Dude, I've not touched mine! It's jetted as it came out of the box!! All I've touched so far is the idle speed screw. : )
Meanken, PYs official "Token Chebby guy"
Old 10-17-2006, 10:30 PM
Scott E. is correct. I worked with both guys: Marty and Marvin many years ago at Holley in Warren, Michigan.
Marvin should know about HP carbs because he and David Braswell designed the thing! Marvin was working as the Performance Manager for the project at the time.
Both guys are straight up, Racers, and good people.
JMO
Old 10-18-2006, 07:22 AM
Thumbs up
I have talked to them at great length at the PRI show. One of the reasons they decided to go their own way was they had ideas on improvements and upgrades to the Holley carb that the Powers that be didn't want to listen to or change.
Glad they decided to go it alone.
Old 10-18-2006, 10:02 PM
When did you do that?
You spent most of the time trying to sneak up on me while I was talking to my friends! LOL!
I am trying to go to the show again this year Kenny. Maybe this year I will have time to see the shop. You going?
Old 10-18-2006, 10:43 PM
J.C.you's Avatar
J.C.you J.C.you is offline
i run a 1150 hp on my 505 and tried a 1250 QF and the car slowed some from the carb being too big i believe. i like the idle and hot cranking of the quick fuel over the holley.
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 10-19-2006, 09:31 AM
Talking
Friends? Friends? Don't go telling lies on this board. LOL.
They are acquaintances. Bwhahahahahahaha.
Yes 'The Dude Crew' will be there.
Old 10-19-2006, 09:44 AM
66bonne's Avatar
66bonne 66bonne is offline
P-Dude put a Quick Fuel on the 455 build he did for my 65 Catalina. It's a 850cfm, manual secondaries. This carb is GREAT !! Very responsive. We launch off idle with no bogs/hesitation. I don't know much about carbs but when I compare the parts on the QF to a similar Holley you can definitely see the difference in craftsmanship/engineering/etc.
Old 10-19-2006, 09:56 AM
Thumbs up Dolp forgot about that one too. LOL
Jim. send me 'all' the specs with drag pics, timeslips and show pics to your ride again.
All the info as Danee' has put it all away. We can put your car up on our website under BADASS rides.
[email protected]
http://www.angelfire.com/fl4/pontiac...RideIndex.html
Old 10-19-2006, 10:02 AM
66bonne's Avatar
P-Dude: thanks for the reminder about the pix and specs. I told Danee I'd send them then my feeble mind forgot !! I'm going to take some more pix of the Catalina at Runday Sunday. We put a phenolic 1" spacer under the Quick Fuel carb to see if that does anything. And I want to finally try those NGK racing plugs I got from you quite awhile back.
See ya there, Jim
Old 10-19-2006, 09:23 PM
76transam76's Avatar
76transam76 76transam76 is offline
I also have a 750 quick fuel carb from Pontiac dude. It is jetted as it came out of the box. Very nice carb, almost wanted to hang it on the wall. I cant compare it to anything else except my qjet that I had before. The only problem I am having with my quick fuel is it is running rich. I dont know if this will help or not, but It looks like my floats need to be lowered some.
1976 trans am. 400 .040" over stock crank, CAT rods, speedpro flat tops, 72cc eheads, rpm intake, quick fuel 750, xe274, 1.5 HS. Built 700r4 (by me) w/3200 EDGE converter. 3.73's hustler headers. Flowmaster exhaust system. 17" torque thrust II's
