Old 10-27-2006, 03:06 PM
paulverkleij paulverkleij is offline
Default performer rpm intake 68 firebird.
at this moment i'm having a 406 long rod engine build... for my 68 firebird 400..
My engine builder says i should use a torker 2 intake for best performance.....
but the car wil only be used for street driving .... mostly just cruising....
so i want to go ... whit a dual plane intake such as a performer RPM
People here in the netherlands say it to high and that it doesnt fit under the hood.....
I'm planning to use a drop base air cleaner with 3" k&n filter + xstream top... normal gasket...
does this fit under the hood ?????
thanks for your help...
paul verkleij
the netherlands
68 firebird ram air 400
99 trans-am ram air ws6
Old 10-27-2006, 03:44 PM
Donovan Donovan is offline
Everyone's car is a little different. But, if it helps I measured clearance on my 68 with a stock engine. With a ball of aluminum on top of the cleaner I shut the hood. I did this 2 times, one on the front edge of the top and one in back. The foil crushed to just under 2" at the thinest. With a drop base cleaner you could have a total of about 4" to play with I'd think. Depends on the drop base assembly too!
Old 10-27-2006, 04:27 PM
Ron H's Avatar
Ron H Ron H is offline
With a drop base 14" x 3" K&N with filter top and a performer rpm I had 3/4" above my cleaner to the hood with a 1/2" divided spacer under the carb.
68 Firebird
Are you running with the wind or breaking it?
Old 10-27-2006, 06:27 PM
firebird400's Avatar
firebird400 firebird400 is offline
I have a Performer RPM manifold in my 68 bird
It has a drop base and a 3" filter element
Your good to go
Old 10-27-2006, 06:35 PM
HOGFRMR's Avatar
HOGFRMR HOGFRMR is offline
I have the same set-up as Ron, with the 1/2" spacer and it clears just fine.If you have your doubts on clearance, buy some play-doh and put it around your air cleaner lid and close it real slow.That will tell you how much room you have.
Old 10-27-2006, 07:59 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
I also have a performer rpm in my 68 bird. I had a street dominator on the old motor and I'm thinking about going back to it.
Old 10-28-2006, 01:05 AM
azbirds's Avatar
azbirds azbirds is offline
I have a Performer with a 1" spacer and my Ram Air pan still fits. It compesses the foam more, but it does fit.
Old 10-28-2006, 10:42 AM
thanks guys
that 's is the kind of info i was looking for !!!
i had already dismanteled the engine .. so i couldnt measure the hight!!!!
now i'm good to go !!!
thanks
paul verkleij
the netherlands
Old 10-30-2006, 06:37 PM
Region Warrior's Avatar
I'm using an RPM intake with 1/2 spacer, 850 Demon, and 3" high a/clr under a std 350 hood.
Engines sit low on 1st gen's like the full size Pontiac's.
