Old 11-02-2006, 03:05 PM
Ron H's Avatar
Ron H Ron H is offline
Default KRE head swap dyno results
Another attempt to get some solid swap numbers went to the wayside. The dyno showed 452 RWHP at 5650 RPM. But the rpms and power was jumping all over the place. After making various adjustements and 8 attempted pulls we called it quits. As soon as the secondaries opened things went goofy.
The consensus is my torque converter can't hold the power against the dyno and was slipping intermitently.
The only other parts that changed besides heads was new push rods. Timing and Q Jet rods were different.
These numbers show a 77 RWHP increase from a well ported 6X-4 head to the 310 CNC 74CC KRE D Ports dynoed on the same machine.
I wanted to swap to 1.65 rockers and see results but things just weren't working right. I have another cam to swap to this winter and am looking to still be on target for 500+ RWHP to start next season.
68 Firebird
Are you running with the wind or breaking it?
Old 11-02-2006, 03:44 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Hmmm, exciting and disappointing at the same time! What convertor are you running (assume a conti 10'')?
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 11-02-2006, 04:09 PM
Ron H's Avatar
Yeah Continental 10". I have emailed them to see if it's normal for a power change of 100+ HP could do this since it was made for less power.
68 Firebird
Old 11-02-2006, 04:22 PM
grandville455's Avatar
nice numbers ron!!! I am sure they will come up even more next year with the cam change to take full advantage of the 310 flow!
Darby
M/T 275/60 ET SS Drag Radial
Old 11-02-2006, 04:34 PM
Ron H's Avatar
Yeah, those numbers were still with the 1.5 rockers as well.
68 Firebird
Old 11-02-2006, 05:20 PM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
can you post copy of your dyno printout graphs w/numbers from before to after now ?
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 11-02-2006, 06:49 PM
Ron H's Avatar
I didn't print one from today as the needle was all over. i have the one from 2 weeks ago that we had the same problem and it showed 430. I changed rods and timing and opened the caps on the cut outs for todays pulls. I will try and post them now.
68 Firebird
Old 11-02-2006, 07:08 PM
KARGUY KARGUY is offline
Ron H
I do not think it is your vehicle that is causing your problem. I believe that the load control on the dyno is not tuned properly and cant hold the extra load. I have run on a Mustang dyno and have seen unstable loading.
I would find a differant dyno before I would suspect your torque convertor.
FWIW,
Karguy
Old 11-02-2006, 08:42 PM
Ron H's Avatar
Yeah we tried a few things to get it to work. The dyno guy said he had a similar problem with a turbo Jag. The converter was slipping.
This is a dyno pack machine. I can't help but think it was the dyno brake not being able to hold on and was slipping causing the problems.
I can't get my scanner working hopefully I will have it by the morning.
68 Firebird
Old 11-02-2006, 09:05 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Ron - I didn't realize you selected the 74 cc heads - what compression iron vs al.?
John
Old 11-02-2006, 09:37 PM
BILTIT's Avatar
''6x heads have a 93cc chamber. KRE's are 74 cc. 9.4 to 1 to 11.1 to 1 change. 6x heads never had the crossover plugged. But I did plug the crossover on the intake.''
Brought it over from the first thread.
Derek B.
Old 11-03-2006, 02:09 AM
cerino2000's Avatar
cerino2000 cerino2000 is offline
Ron, what's the rest of your build look like? Gotta be happy with that kind of power for sure! (Well, at least I would be)
Old 11-03-2006, 02:27 AM
BVR421's Avatar
BVR421 BVR421 is offline
I hate gynomometers.
Old 11-03-2006, 08:27 AM
Ron H's Avatar
I am not a huge fan of them right now either.
68 Firebird
Old 11-03-2006, 08:51 AM
Ron H's Avatar
75 455 .030 over, Stock crank, CAT rods, SRP Pistons, U/D Solid 247/255 @ .050 110* LSA .525/.540 lift, !.5 HS roller rockers, KRE 74 cc D Ports, RPM Intake, Cliff's Q Jet, Pertronix Dist with MSD Cap and Coil and 6AL box, 2 Step , Doug's headers, Continental 10", TH400 with a kit, Ford 9" with 3.89 gears, 33 spline Moser Full Spool and Axles, 3" Pypes exhaust With Cut Outs and Race Pro Mufflers, CSR Electric water Pump, Alum Rad with Dual Fans, Centerline Auto Drags , Skinnie fronts, M/T 275/60/15 Drag Radials, QA1 Coil Overs front, Summit 3 way Adjustable rear, Calvert Racing Split Mono Leaf Springs, Slide A Links, Full interior, Full Steel except Fiberglass Hood, 8 Gal Fuel ell, Mallory 140 Fuel Pump, -8an lines, Battery In trunk, 100 Amp 1 wire Alternator.
This winter U/D 255/263 Solid 108* lSA .540/.556 cam and 1.65 rockers. Freshen bearings, rings, fill the block, maybe upgrade Rods but I think they will be OK.Add a windage tray and crank scraper, new Oil pump.
Rebuild trans and add a brake. Send in Converter to match new combo.
Completely strip car, blast, clean up rust, install Roll Bar, Paint.
Hopefully go racing in Vegas/Phoenix mid-end of March?
68 Firebird
Old 11-03-2006, 09:46 AM
70 lucerne lemans's Avatar
70 lucerne lemans 70 lucerne lemans is offline
We have very similar combos,Im curious to see what yours dynos at with the 1.65s ,thats going to put you really close to .600 lift.
Mark
1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD....
1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs
(1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor
[email protected] on 150 shot
Old 11-03-2006, 10:14 AM
Ron H's Avatar
I will be if the HS 1.65 rockers are 1.72 as many have said they are. that would put me at .593 after .026 lash intake and .610 exhaust with the other cam. I really wanted to see how much more power i'd make swapping them with my current cam.
68 Firebird
Old 11-03-2006, 10:29 AM
Armadillo Armadillo is offline
452 is good power am also interested to see what the other upgrades will do. You are running more cam that what I have now (HR288). Shame there isn't a track for you to test on also. Thanks for keeping us informed.
Tom
Old 11-03-2006, 10:49 AM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
Default Actual HP...
Ron, I was surprised when I ran the numbers so far! Your 452 RWHP comes in at 587 FWHP! This is assuming a 23% driveline loss.
Is this correct? If so then the combo seems to be working! I'm not sure if you can make the 650HP you seek without going roller? Ron wrote... " I wanted to swap to 1.65 rockers and see results but things just weren't working right. I have another cam to swap to this winter and am looking to still be on target for 500+ RWHP to start next season." The reason I say this is 650 minus 23% is 500.5
I think it's very possible to get 600 FWHP as there are a few guys on PY getting there! Congratulations and keep up the good fight! Good luck! JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 11-03-2006, 11:08 AM
Ron H's Avatar
I am calculating 18-20% loss. 510 RWHP is my goal and with 20% loss that's 612 on the engine. If it's 18% loss I would be 601.8 on the engine.
This is with an RPM intake as well.
To make more I definately would need more cam, carb and intake volume.Probably bigger headers as well.
68 Firebird
